TX-55DX600B one (1) blink SOS code
  • Tom0
    • Sep 2018
    • 3
    I have a TX-55DX600B bought 16 months ago from Panasonic outlet on Ebay, seemed cheap at the time. Worked well up until now I have the following issue;
    Turn on.
    green light flashes quickly for maybe 3 seconds.
    then screen flashes (can only see if back cover is off, or if in dark room.
    Red light continues to flash every 3-4s.
    I believe one blink code.
    I checked for short on PDU - P board with meter from fuse (which received V) to ground and none - is this correct?
    I have ordered an A board, coming this week (can return at cost of postage).
    If its not the A board - I believe it is relating to Backlight LED - BL_SOS (LED driver).
    Question - Am I correct in my assumptions - I got info from this forum and also;
    If not A board, should I try P? or is this likely to be LED strip - in which case is it worth bothering, simple enough for a normal person to manage? I guess I'd need suction cups and two sets of hands.
    Attached are images of back of board.
    Any help / advice appreciated, Would really love the SM for one of these if someone has one.
    Thanks,
    Tom.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: TX-55DX600B one (1) blink SOS code
    Looks like the Backlights have failed.
    • Tom0
      • Sep 2018
      • 3
      Thanks for the reply.
      Could I ask what makes you say that and also would you advise to attempt repair? All led’s or just the faulty strip?
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
        LCD LED TV Service Menu Codes
        ALL LCD LED TV SERVICE MENU CODES
        Service Menu Code with Board Name
        China Universal Board / Jumper Board Service Menu Code
        Changhong Ruba Service Menu Code
        Ecostar LED TV Service Menu Code
        Orient LED TV Service Menu Code
        Haier LED TV Service Menu Code
        TCL LED TV Service Menu Code
        Samsung LED TV Service Menu Code
        LG LED TV Service Menu Code
        Videocon LED TV Service Menu Code
        Supra LED TV Service Menu Code
        Toshiba LED TV Service Menu Code
        Symphony LED TV Service Menu Code
        Veste/ LED TV Service Menu Code...
        10-31-2024, 03:58 AM
      • Hakuu
        by Hakuu
        Hi There,
        More Details
        TV Model - LG OLED77G1PUA
        07-12-2023, 02:37 PM
      • jb_Bak
        by jb_Bak
        CN6401
        Pin 01 NC
        Pin 02 NC
        Pin 03 "BL_ON": 0V
        Pin 04 "N/C"
        Pin 05 "STBY 3.3V": 3.5V
        Pin 06 "GND": N/C
        Pin 07 "AC_OFF"...
        09-27-2021, 04:52 PM
