Samsung PN59d6500 power cycling issues
  • rab1dsqu1rr3ls
    • Sep 2018
    • 9
    I know this is an old topic and I've searched over and over but can't seem to figure it out.
    So I got this tv from a friend because he was getting rid of it due to the power cycling. I've been trying to fix it for the past few weeks and can't seem to figure it out and wanted to reach out to see if y'all could help me out a bit.
    It'll get past the smart tv logo, run for 3 minutes then shut off.
    So to start I followed along with this video https://youtu.be/JjrwTZC5nVg and got all the values it said I should get. When I put it in the color test mode it ran for without resetting it, which means it should've been a bad main board (BN94-04709a). I ordered a replacement from Tvpartstoday and replaced it. The issue was worse resetting every 5-15 seconds. So I thought it might be a logic board. I tried the new logic board with the old main board and the new main board. Same results (3 minutes with old, 5-15seconds with new board).
    My only thought is that it could be the power supply board at this point. Or that one of the replacements they sent is bad.
    I've looked over the PS board and there's no bulging or leaking at the tops of the caps. Nothing seems apparently bad. Would this be the issue? Do I just need to wait for it to come back in stock somewhere?
    I can share pics and any other info needed. Any and all advise will be appreciated. Thanks guys
  • rab1dsqu1rr3ls
    • Sep 2018
    • 9
    Re: Samsung PN59d6500 power cycling issues
    Sorry for the bump. I'd like to know if I need to look for that board as it is out of stock everywhere. If it comes in stock I wanna get it ASAP if I need it
    • tvtimmy
      • Mar 2015
      • 1160
      • usa
      Look under the mainboard for c102. Look up c102 on the forum for alot of info.
      • rab1dsqu1rr3ls
        • Sep 2018
        • 9
        I’m having a hard time finding it. Here are the two boards, back and front that I’ve replaced. Is c102 on these? https://imgur.com/a/meL9flG
        • tvtimmy
          • Mar 2015
          • 1160
          • usa
          It would be on the back of the mainboard, not the logic. There probably isnt one but I would still check.
          • rab1dsqu1rr3ls
            • Sep 2018
            • 9
            The second 2 pictures on that imgur post are the main board. You don't me the Powersupply board right?
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              No.
              • rab1dsqu1rr3ls
                • Sep 2018
                • 9
                There are no caps under the main board and I can't seem to find c102 on top.
                • ajshoe
                  ajshoe
                  • Dec 2012
                  • 477
                  • usa
                  main board ic1302 is faulty. not an easy repair. suggest Nickstv repair.
                  • rab1dsqu1rr3ls
                    • Sep 2018
                    • 9
                    Thanks. I've reached out to them. Should I try to return and exchange the board I ordered? Is it a faulty replacement?
                    • ajshoe
                      ajshoe
                      • Dec 2012
                      • 477
                      • usa
                      run test pattern (leave lvds cable connected & short pins 3-4 on logic bd)
                      if set stays on with test pattern (check display for defects) - bad main bd. You probable got a bad main bd on replacement. most common on these sets.
                      • rab1dsqu1rr3ls
                        • Sep 2018
                        • 9
                        I did that and it stayed on. I'll try getting another replacement board from them
                        • rab1dsqu1rr3ls
                          • Sep 2018
                          • 9
                          Annnnnd they're out of stock. I asked to see if they can fix it. And said that it's possibly ic1302. But we'll see what happens. They'll refund me if they can't.
                          How much does nicks chards for board repair?
                          • killerz298
                            • Dec 2018
                            • 11
                            Woke up this morning to same problem. Set stays on for 3 mins 10 seconds working perfectly then power cycles No issues last night. Thinking of buying a new main board or sending this one in for repair. Did you manage to fix your set?
                            • ajshoe
                              ajshoe
                              • Dec 2012
                              • 477
                              • usa
                              Yes. Id use Nick's tv. Mine still working perfectly
                              • killerz298
                                • Dec 2018
                                • 11
                                It was your main board? I don't want to waste $100 if that isn't going to be my issue. Does it sound like that is the issue I'm having? 3 mins on then power cycle? TV works fine when on, responds to remote, etc...
                                • ajshoe
                                  ajshoe
                                  • Dec 2012
                                  • 477
                                  • usa
                                  read post #11 again
                                  • killerz298
                                    • Dec 2018
                                    • 11
                                    read post #11 again
                                    So I'm trying to disconnect the LVDS cable and this thing won't budge... what am I doing wrong? I pinch the black clips on the side but I can't seem to pull the cable out and don't want to snap it.
                                    Figured it out.... I didn't have the flat black clip popped up all the way. I ran the pattern test and the tv doesn't shut down. I guess I need to send this out for a main board repair as the cheapest one I see to purchase is $179. When I send this board in for repair, I only send the board right, none of the wires/connectors?
                                    • ajshoe
                                      ajshoe
                                      • Dec 2012
                                      • 477
                                      • usa
                                      look at the lvds connectpr closely - have to disconnect relief tab first - then squeeze tabs to release. only board.
                                      • killerz298
                                        • Dec 2018
                                        • 11
                                        Yup got it now... Test pattern stayed up and tv didn't turn off so I'll try a board repair. Hopefully it saves the TV.
                                        • ohren
                                          by ohren
                                          09-08-2023, 05:24 PM
                                        • C152Heavy
                                          by C152Heavy
                                          Summary for TL-DR readers:
                                          • VCC pin (18) of PFC...
                                          01-11-2023, 02:53 PM
                                          09-07-2024, 05:50 AM
                                        • iam5
                                          Intermittent USB-C / USB-A issues + Trackpad Freezes — T14s Gen2 (11th-gen Intel) — Seeking Board-Level Advice
                                          by iam5
                                          I’m looking for advice on board-level troubleshooting and potential component-level repairs for a Lenovo ThinkPad T14s Gen2 Intel (i7-1185G7) showing multi-domain instability. Hoping someone familiar with this platform (or the related X1 Carbon Gen9/Gen10, X13 Gen2, X1 Nano Gen1/2) can point me toward the right section of the board to inspect, and whether any of the known fixes apply. Symptoms:
                                          1. Trackpad (CS21 module) intermittently freezes during active use
                                          • Not tied to lid open/close
                                          • External USB mouse continues working
                                          • Sometimes recovers with sleep/wake
                                          • Looks like
                                          Today, 09:29 AM
