Proscan elite EP 5585 Turn On but led driver no voltage ..
  • mydang
    • Aug 2018
    • 61
    • canada
    Hi! all and Budm
    Led TV Proscan elite EP 5585 is problem... Tv turn on green light is stable
    tv screen flash then black
    checked led driver both way connected and disconnect to led string when first tv turn on 124 volts at led driver channel, then voltage drop to 0 volt 100% problem with power supply produce led voltage
    Because I already checked led backlight with led tester backlight bright and voltage show on tester 94 volt 100% no problem with led backlight
    I just all professional help me what component cause Tv turn on i have 124Volt but drop to 0
    Thank you all
  • R_J
    • 9535
    Re: Proscan elite EP 5585 Turn On but led driver no voltage ..
    You could have a bad led in one of the led strings, If one led is shorted the string will light with the tester but the tv's power supply monitors the current and if it is over a set limit it will shut down.
    • mydang
      • Aug 2018
      • 61
      • canada
      led voltage drop from 124 v to 0v even disconnected to led power supply
      problem is from power supply led driver
      Thank RJ
      • mydang
        • Aug 2018
        • 61
        • canada
        I tested 2 led string is 94V each , the same voltage both and the backlight is bright
        • R_J
          • 9535
          • kerfooly
            • Apr 2020
            Originally posted by mydang
            Hi! all and Budm
            Thank you all
            Hello
            I also have the exact same TV, and a similar issue, where the backlight comes on when I turn on the TV and everything is fine, but it goes off after 15min or so on any input or picture setting, and I have confirmed it is a backlight issue with the flashlight test, and I do read similar voltage values
            while Im very new to all of this, my question is, is my issue the same board too?
            and if it is, is there any way I can identify and repair the faulty part of this mainboard/power supply combo without having to purchase a new one
            Thanks in advance
              What happen if you turn down the Backlights level (not Brightness) down to as low as possible, will the backlights stay on longer than 15 minutes?
              • neilc6
                • Nov 2015
                • 1550
                RCAs don't have the ability to turn down the backlight in the picture menu. Some have a power savings picture mode with a reduced backlight level.
                To turn down the backlight, with TV on, try source-2-5-8-0 or menu-1-1-4-7 Look under Panel Settings or Other Settings. Be very careful in the service menu since you can brick your tv. Set it to around 50 to 60. You may need to do this on all inputs.
                  HP Elite Elite 7200 MT Elite 7200 i5-2400 Specification for Upgrade or Repair
                  This specification for the HP Elite Elite 7200 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7200 MT boardview and Elite Elite 7200 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-12-2024, 03:44 PM
                  HP Elite Elite 7100 Microtower PC Elite 7100 i3-530 Specification for Upgrade or Repair
                  This specification for the HP Elite Elite 7100 Microtower PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7100 Microtower PC boardview and Elite Elite 7100 Microtower PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                  HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                  This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                  HP Elite Elite 7300 MT Elite 7300 i5-2400 Specification for Upgrade or Repair
                  This specification for the HP Elite Elite 7300 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7300 MT boardview and Elite Elite 7300 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                  09-12-2024, 03:30 PM
                  HP Elite Elite 7300 MT + YD304AA Elite 7300 i3-2120 Specification for Upgrade or Repair
                  This specification for the HP Elite Elite 7300 MT + YD304AA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7300 MT + YD304AA boardview and Elite Elite 7300 MT + YD304AA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                  09-12-2024, 03:28 PM
