Vestal backlight strip 7020pkg 72ea
  • crt man
    • Mar 2013
    • 106
    • England
    Hi
    Has anyone got the above backlight strip that is for parts or failed,
    I am after the socket for them as the one on the board I am trying to
    repair has suffered irreparable damage.
    Alan.
  • triplefour
    by triplefour
    09-13-2023, 10:43 PM
  • edugimeno
    Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
    by edugimeno
    Hi There!
    I'm trying to help my friend who owns a restaurant be just bought.
    He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
    It's stuck using, I guess, the 2 sided tape that comes with the strip
    The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
    09-05-2024, 09:34 AM
  • DanPoka
    Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
    by DanPoka
    I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
    Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
    This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • DXseekerMO
    Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
    by DXseekerMO
    Hello everyone!
    Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
    I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
    Yes
    0%
    1
    All backlight strips are the same quality
    0%
    1
    No
    0%
    0
    12-16-2021, 03:58 PM
