Samsung 40 inch lcd
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Samsung 40 inch lcd
    Hello, forum, I picked up a non-working tv, It had no power at all, not even a standby light.
    On inspection noticed 3 caps had blown 1000uf 10v/25v on the main board,i changed these along with one of the same value, as though three was out no doubt would be the same with the remaining one.
    WIN it works and not bad for an older set, strange no on or off button on the tv itself not even on the back.
    The issue I have or is it an issue when you switch on with the remote, it blinks four times then the tv comes on, is this normal?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Samsung 40 inch lcd
    as long as it works, turns on and stays on, I wouldn't worry about it.
    • neilc6
      • Nov 2015
      • 1550
      Some of the Samsung LCD's have soft buttons on the bottom front that are not very obvious. Blinking is a sign that it is booting up. You could look up the user manual searching the model number.
      • Kjell
        Samsung Series 9 - BIOS issue
        by Kjell
        After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
        Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
        08-01-2025, 09:15 AM
      • Acnologia
        Lenovo Thinkpad T540P - Showing at 14" inch but NOT at 15.6" inch (Backlight issue) ?
        by Acnologia
        Hello to all members of badcaps.
        Another brainstorming that i have been messing with for months as a side project.
        Bought a T540p , from eBay as 'doesn't display' ,so i thought it was either backlight fuse, or screen issue etc.
        I got it in my hands, first thing, the machine works fine boots to windows , in external screen all diagnostic are good.
        Step 1.
        Change screen (FAT - LED ) 1366x768 to 2nd one, that i know 1000% that is working ,as it has been tested.
        Machine > Doesn't give display it's really dim.
        Step 2.
        Use the same...
        11-05-2025, 04:02 AM
      • Nairolf
        Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
        by Nairolf
        I have a Samsung DM32D display.
        When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
        Here’s what I have tried so far:
        1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
        2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
        3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
        From these tests, I suspect the problem might be on the mainboard. Could anyone...
        08-24-2025, 03:47 AM
      • vincentedel
        Samsung SyncMaster 740n Phase Control Issue
        by vincentedel
        I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
        I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...
        04-22-2025, 12:33 AM
      • Manucsl
        QE65Q800TATXXC Samsung TV Issue
        by Manucsl
        Hello.
        My TV is a QE65Q800TATXXC Samsung TV.
        Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
        Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
        Any ideas to check would be very appreciated 😊
        After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump...
        02-19-2025, 07:47 AM
