LgTv 55lm860 thin horizontal lines equally spaced
  • paulusone
    • Aug 2018
    • 3
    My lg has horizontal lines spaced apart about 6mm from top to bottom more dominate on right hand side, have disconnected tcon output left and right one at a time the left one removed gives a clean picture, the right output removed and the lines are there, suspect the panel or the thin wide pcb's at the bottom of the chassis cant seem to get the ribbons undone help would be appreciated for access to these.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LgTv 55lm860 thin horizontal lines equally spaced
    Clean and re-seat the LVDS cable from the Main Bd to the T-CON Bd and the two FFCs from the T-CON Bd to the Panel. This looks like the T-CON Bd is not producing the CPV1, 2 and 3 signals.
    • paulusone
      • Aug 2018
      • 3
      Thanks for reply help needed how to unlatch ribbons to lower panel pcb's close inspection shows witness marks of previous attempt, could it be the tcon as I assumed the tcon produces vertical error, see attached picture for ribbon cables other cables re seated no change, could try tcon in oven to reflow and will look at circuit to find cp1 etc
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4541
        • Italy - Milan
        I ask you to use commas and other symbols first..
        Don't reflow tcon, it's a panel defect. I guess the tcon is on the bottom, check the model code of the panel, if no label present check the main tcon chip's brand. I guess the problem can be on the panel's board. To F.Ali: CPV are clock signals? How can them matters on this case? It stands for Clock Pulse Vertical? i'm away from home i can't check my notes...
        A possible remedy: search for STVP testpoint on tcon, check with DMM to which of the pins on the connector versus the panel's faulty side it goes, then take adhesive tape , cut a thin stripe an place i to mask only that signal on the flat cable. Test tv.
        • budwich
          • Jul 2015
          • 3097
          you are likely on the right track about the cable clamp at the bottom. The clamp mechanism is the same as the other ones that you disconnected at the tcon... the "clamp" lifts up.... try using a credit card as a "lever" across the whole clamp "lever". Since you get a good picture with the one side disconnected, it is likely the cable and / or clamp on the other side that has an issue... could be even as simple as a misalignment and might be the reason that you are having such a hard time unclamping the connector.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Originally posted by davi.p
            i ask you to use commas and other symbols first..
            Don't reflow tcon, it's a panel defect. I guess the tcon is on the bottom, check the model code of the panel, if no label present check the main tcon chip's brand. I guess the problem can be on the panel's board. To f.ali: Cpv are clock signals? How can them matters on this case? It stands for clock pulse vertical? I'm away from home i can't check my notes...
            A possible remedy: Search for stvp testpoint on tcon, check with dmm to which of the pins on the connector versus the panel's faulty side it goes, then take adhesive tape , cut a thin stripe an place i to mask only that signal on the flat cable. Test tv.
            +100
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
              HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client Specification for Upgrade or Repair
              This specification for the HP Mobile Thin Client mt44 Mobile Thin Client 3JG86EA Mobile thin client can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the mt44 Mobile Thin Client 3JG86EA boardview and mt44 Mobile Thin Client 3JG86EA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
              09-06-2024, 06:50 AM
            • Andriod
              LG 47LN577 with black fading horizontal evenly spaced lines
              by Andriod
              So, I have searched the internet for long, high and low and ended up here.
              As the title suggests; there are static repeating black-ish horizontal lines that start from the left and fades away at around 65% toward the right, meaning its length is more than half the screen. The lines are from top to bottom evenly spaced. I can see the lines on the test image, and on chromecast input.
              This is my first time investigating TV errors at this level, and my initial googling led me to believe it was the T-CON board, considering that it has a left-ish problem. But googling even...
              12-30-2020, 03:38 PM
            • ggil44
              Sony XBR-65X750D Horizontal lines bottom of screen
              by ggil44
              Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
              05-30-2023, 07:51 PM
            • rstrube
              ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
              by rstrube
              Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
              Hi Everyone,
              I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
              Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
              11-23-2025, 01:37 PM
