Toshiba 47l6200u logo stays and backlights stays on.seems to be issue on main board.Cant access the main menu either.
toshiba47l6200u logo stays indefinately and backlight stays on.
Tags: None
Re: toshiba47l6200u logo stays indefinately and backlight stays on.
A couple of repair services for the main board on ebay if you search the main board part number or model number. Fixes for stuck on logo issue. Also a seller of the NAND Flash U3.
https://ebay.us/34UinI
https://ebay.us/VpgNhMComment
Thanks for reply ...awesome forumComment
Asus Strix G513QR-HF016
Motherboard: G533-MP-GBM, 6050A3250202-MB-A01
The motherboard powers on, the Strix logo appears, then only the backlight stays on — it does not enter the BIOS and hangs at that stage.
The laptop arrived with a broken screen and a damaged display cable.
Actions performed:- New BIOS dumps have been flashed
- A new Ryzen 7 CPU was soldered in (tested with two different units), but the issue remains the same with both
- Tested with a different display cable and screen
- No missing components or visible damage on the motherboard; no components
09-29-2025, 01:02 PM -
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by robgerrGood morning forum. , This notebook has problems with the backlight being absent. If I shine a flashlight on the screen, i can see the image. I tried to change several LCDs but the same problem. When I disassembled it, I noticed the LVDS connector was a little burned in the backlight pins. I also found oxide in the LVDS connector on the motherboard. I replaced the LVDS cable, same defect. I replaced the LVDS connector on the motherboard, same problem. I took some measurements on the pins (I used the boardview of the X580VD).
pin 36,37,38,39 19,40v
pin 35 no connected
pin... -
by mrtekHi.
picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED... -
by BoardHoarderCurrently trying to save a 65” 850D that definitely has a main board issue. Power supply has standby voltage and PS ON pin shows 3.5VDC but main has no signs of life…..no light under Sony logo and no optical port lit up. 12VDC is created by main board but no input triggers from main = no TCON 12V and no BL ON voltage present. I know about the trick of pulling the main to trigger the test pattern from the TCON but I get no backlight. If I jumper the 3.5VDC to TCON ON and BL ON, I can shine a light on the panel and see solid green, red, blue and white cycling. The 4 + backlight pins on the power...
- Loading...
