Quasar SQ5500u Led backlight failure.
  • SEAWOLF
    • Nov 2011
    • 177
    • Barbados West Indies.
    I presently have a Quasar SQ5500U television with backlight failure but I am unable to find a service manual for this tv.Can anyone say where I can find this manual?
  • OkElectronicsRecycling
    • Feb 2019
    Re: Quasar SQ5500u Led backlight failure.
    A bit late to the party here, but I would like to add some input here. I got 3 of these family of TVs in and 2 were SQ5501u models. Only one PSU had bad caps, but the other two had multiple bad LEDs in the strips. Since the LCD panel itself isn't in a bracket for easy removal, you are going to need at least 2 sets of hands to avoid cracking it. Even then, expect a gamble. Wear gloves, have clean hands and have a nice soft, flat spot handy to place the LCD panel (I use a workbench with a shipping blanket over it).
    Using a $20-25 LED tester will help a ton in locating the bad strips. Probably just going to combine 2 of the TVs into one working unit. Keep in mind that the wire lengths for the LED harness are really wonky and to check to make sure the sheet metal from the TV back isn't cutting into and shorting the LED wires out.
    If there is a service manual for these things, I would be pretty surprised. Brands like LG, Sony, Samsung and other 'name brands' tend to have an interest in working with their technicians. With Quasar, I think they just do replacements instead of repairs. I could be wrong, but that seems to be the case with economy brands.
    Don't let that deter you nonetheless.
    • gaelican
      Odyssey G9 Neo backlight partial failure.
      by gaelican
      I have an Odyssey Neo G9 that I was working on for a separate issue. After removing the motherboard and putting it back a few times I noticed that the lights on the display have stopped turning on altogether. I was able to determine that when the middle section for the backlights is disconnected, then the left and right side turn on, indicating that the fault is obviously in that area.
      After closely inspecting the mainboard I noticed that on the back side of it a few capacitors have been partially moved, one fully knocked off. I replaced the missing one with a new cap with the same...
      02-27-2025, 02:39 PM
    • howardc64
      Vizio E55-F1 dark backlight zones. LED failure or Dimming Zone Driver?
      by howardc64
      Problem
      Fixing a dimming zone TV with LEDs not lighting up. Dimming zone circuit introduces added variable to diagnose LED and/or Dimming Zone Driver board? Some 1/2 rows of LEDs appears to be out in active dimming zone off AND some brightness flickering with active dimming zone high while playing changing video
      Model & Board Pics
      Conflicting Spec
      Vizio indicate this TV has 10 dimming zones. However, LED strips and Zoned light driver connector suggest 12
      https://www.shopjimmy.com/vizio-gj-2k1...
      10-10-2024, 01:16 PM
    • triplefour
      by triplefour
      09-13-2023, 10:43 PM
    • howardc64
      Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
      by howardc64
      Eventually discovered a burn mark near lower corner of LCD. Here is a summary
      • Backlight on, no image
      • Disconnect right buffer board (view from front), left side display comes on
      • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
      • Buffer board is pretty simple
      Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
      07-11-2025, 04:04 PM
    • DanPoka
      Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
      by DanPoka
      I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
      Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
      This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
      02-15-2025, 05:05 AM
