Hpt5054 no power no clicking
  • tvprobs
    • Aug 2018
    • 27
    So I've recently inherited a 50" samsung plasma that was working up until a move. It had issues with powering off at random times and is now completely dead. The inrush current thermistor was blown and cracked when i opened it up and I've been trouble shooting for a little over a week to no solution. I'm pretty novice, but i have an electrical engineering background from school, but changed up because i liked the hobby more than the schooling. I'm handy with tools like multi-meter and soldering iron. However, i seem to lack the expertise needed to crack this one.
    I'm getting a stby of 5.1V and a PS-On of 4.3V. If it wasn't for the blown thermistor i would have assumed an issue with the Main bored first. I've gone through and re-flowed solder to a few joints. Got some replacement parts in. Switch was melted and changed out the thermistor. I have the Vs and Va kit, but so far everything i've pulled (transistor/mosfet) wise have tested well.
    I'm only getting 1.8V on my 5.3V, 18V, and 12V points. I'm thinking it must be a Va or Vs issue because I'm getting good voltage through the AC/DC (163VDC) portion and up to the transistor that powers the switches to the bridge rectifier.
    Short of just replacing every resistor, transistor, and MOSFET that's in the kit, or testing 1 by 1 every component out of circuit i'm at a loss. Tell me what you may need from me and i'll send the info your way.
    Thanks in advance!
  • R_J
    • 9557
    Re: Hpt5054 no power no clicking
    If the thermistor (NT801s) is blown its likely the relay is bad, The relay contacts short across the thermistor when the tv is turned on, when the relay contacts go bad, all the curent passes through the thermistor causing it to open
    What switch was melted?
    Post pictures of the board or at least the bn44 number
    • tvprobs
      • Aug 2018
      • 27
      BN44-00162A (PSPF531801A) switch RL801S was melted and i've replaced that one. I have another on hand to replace RL802S, but i've seen no reason to replace it so far. I've plugged it back in and cannot get it to even click the relays. I'm getting <1V hitting them which isn't enough to bring them on. I've followed the schematic and found QQ803 is getting 20VDC through the Emmiter and Base. I'll post pictures tomorrow, but the schematic is attached.
      • tvprobs
        • Aug 2018
        • 27
        Here are the pics for the board with the switch and thermistor replaced. I did have to scrape away some of the board to get the thermistor re-attached, but otherwise it appears in decent shape.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          So what voltage does ICQ805 has on the input / output pins?
          • tvprobs
            • Aug 2018
            • 27
            ICQ805 is showing .01V at input. .03V at output. -.23V at GRND.
            QQ803 showing 20.2Ve. 20.3Vb. and -.03Vc.
            CQ807 showing .13V at positive terminal.
            Strange finding. I've been working mostly with the board off the TV. However, i decided to do some other fact checking. When i plug the main board in, all of my Va, Vs, Standby, PS_ON, 5.3V, 18V, 12V, points all fluctuate between .3V and -.3V
            However, when it's not plugged in everything is stable to the voltages mentioned in the first post.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              With the mainboard disconnected do you have the standby voltage ?
              If ICQ805 has no voltage In/Out (15V regulator) then the relays cannot be energised.
              • tvprobs
                • Aug 2018
                • 27
                I have the standby voltage of 5.2V when not connected. Also have PS_ON of 4.3V.
                That's where i'm starting to be at a loss. I really need to try to narrow this down before i just start pulling parts 1 by one at semi-random.
                I feel like i should have my 5.3V with or without the board plugged in and am curious if i need to work back from there. I just don't know enough about how the voltage changes throughout the TV once the main board is hooked up and the TV tries to kick on. I'm sure there may be 1 part or multiple part failures when a thermistor blows, but i cannot seem to track down any visual clues with and without a multimeter.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  With the mainboard disconnected from the power supply if you short PS_On to Ground (0 Volts) do the relays click on even if only momentary.
                  • tvprobs
                    • Aug 2018
                    • 27
                    when shorted nothing happens at the relays. So still not voltage going to the rectifiers. Va, and Vs test points drop to negative voltage. Va=-2.8V(spikes to -4.1V then falls to steady voltage) and Vs= -4.1V.
                    • R_J
                      • 9557
                      Using hot ground. Check the voltage on QQ803 (E), (C) and (B). QQ803 supplies voltage to the ICQ805 regulator (in) and the 15 volts output goes to the relay RL802s so QQ803 Emitter is likely around 20 volts
                      Using cold ground measure the voltage on QQ851 (C). when power supply is OFF this voltage will be low, when power supply is ON this voltage should go high 3 to 4 volts. this will light the opto coupler PCQ802 causing the photo transistor part to go low.
                      QQ810 should be turned on via RQ837 providing the ground for the opto PCQ802 emitter so when the optos photo transistor is on RQ819 goes low (to hot ground) turning on QQ803
                      • tvprobs
                        • Aug 2018
                        • 27
                        OK. here's what i've found so far.
                        OFF STATE:
                        QQ803 E: 20.2V C: -0.03V B: 20.3V
                        QQ851 E: 0V C: 0.09V B: 1.8V
                        QQ810 E: -0.05V C: 0.18V B: 0.18V
                        Resistors match the output
                        ON STATE (PS_ON goes to ground 0V):
                        QQ851 E: 0V C:1.4V B: 0V
                        Opto-coupler getting +.9V on anode 0V on cathode
                        QQ810 E: 0.7V C:0.2V B:0.2V
                        QQ803 E:19V C: 12-13V B: 19V *****These voltages are bouncing.
                        ICQ then puts out a voltage bouncing between 10.9V and 11.5V which goes to Vcc.
                        Relay 801 is only getting 0.2V and relay 802 is getting voltage bouncing around 11V. Diodes seem good on these too.
                        If i put my lead on +side of relay 802 it will actually click on then off when i was testing. I'm thinking maybe a bad capacitor somewhere is causing this voltage to bounce around? i followed my bouncing voltage and it seems to be coming from the PFC side. VAC standby input is steady.
                        • tvprobs
                          • Aug 2018
                          • 27
                          So update on the TV front. After working back through the board after the testing above and pulling some components just to be sure they were good. I found that on top of 1 cap being low. There were blown joints on the second relay. TV has been up and running for over an hour and seems great. Thank you all for the help. It definitely pointed my in the right direction to finally solve this case. I had been working on it for a while.
                          • R_J
                            • 9557
                            Good to here its working.
                            • nmbb
                              Can not find Model/Value of Thermistor.
                              by nmbb
                              Machine: Autoclave.
                              Brand/Model: SANYO MLS-3780
                              Manual: (Sorry search option not working on this PDF)
                              Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                              06-02-2022, 05:55 PM
                            • socketa
                              Corsair TX650W fuse, NTC thermistor, and (APFC? Power Transistor) fried
                              by socketa
                              I read through this thread, and just want to confirm what i should do.
                              https://www.badcaps.net/forum/showth...hlight=24N60C3.
                              This person's fault was exactly the same as mine, even down to the power strip and with the muffled popping sound.
                              I suspect that my problem started with an old power strip, of which a computer and a 2000W heater were plugged into...
                              I noticed melting and heat where the heater was plugged in, so i plugged the heater directly into a double wall socket, but still noticed the muffled pop sound when i turned on the computer, and...
                              07-18-2021, 02:09 AM
                            • B0r1s
                              Samsung UE49KS7000SXXH - fast clicking sound in standby mode
                              by B0r1s
                              PSU - BN44-00878A
                              Symptoms:
                              The TV turned itself off, and I haven't been able to turn it back on. The standby voltage was unstable and lower than it should be.
                              A weak clicking sound was coming from the transformer.
                              Video with clicking sound:https://www.youtube.com/watch?v=lAduhjNtqCA
                              Progress:
                              After the transformer, I measured four Schottky diodes. DM862C and DM864C diodes readings were 003 in both directions. After detaching them from the circuit and measuring them, DM864C was the shorted one. These Schottky diodes are SB550.I...
                              01-17-2023, 04:58 PM
                            • Use2bavolvo
                              Magic chef oven - thermistor ref voltage issue
                              by Use2bavolvo
                              I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                              Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                              01-19-2023, 01:32 AM
                            • slimmy182
                              [SOLVED] M1 MacBook Pro clicking sound logic board 5V no power on A2338 820-02020
                              by slimmy182
                              Hello, I bought this Mac from a friend, he said that it simply stop working. The MacBook looks very clean but does not power on, stuck on 5v 0.42A, and sometimes display 5V and 0A (then 0.071A and again 0A).
                              I opened it looking for some problem, it was not touched before for sure and the board is very clena, no spot of corrosion at all from what I can see. Voltage on multimeter of the board off the case it's the same, 5V 0.42A. But then I noticed this "clicking sound" come from the board ( I attached here the audio file).
                              Looking on google I found this:...
                              01-14-2023, 11:55 AM
