Hitachi Le42h508
  • martystv
    • Aug 2014
    • 20
    • usa
    Hitachi Le42h508
    with this model I commonly get a problem with it just being totally dead, Alomst always when faced with this problem I have to replace a diode(d305)-(uf5408 diode)
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • wolf1976
    hitachi 50hk5600 problem with display
    by wolf1976
    hi
    i have the above tv and the display starts distorts the display at only in applications like you tube
    after and on the didital channels
    now without connect the antenna only the image of itsselfs tv i have the image i have in attach
    i have read in another forum someone else with similar problem with mine changes tcon card and motherboard and the problem remains
    can you tell me someone what is the reason that can causes that problem ? is the same the sisplay ?...
    09-13-2025, 02:26 PM
  • massimomax
    Firmware TV Hitachi 32HE4500 scheda madre Vestel 17MB211S matrice: VES315UNVL-2D-N11
    by massimomax
    Chiedo aiuto per problema a TV Hitachi 32HE4500 che non si accende più,ho bisogno del firmware della scheda madre vestel 17MB211S codice pannello VES315UNVL-2D-N11 ?
    spero che qualcuno può averlo per riprogrammare eprom. grazie
    Post in English !!!
    I ask for help with a problem with a Hitachi 32HE4500 TV that no longer turns on, do I need the firmware for the Vestel 17MB211S motherboard, panel code VES315UNVL-2D-N11? I hope someone can have it to reprogram eprom. Thank you
    02-28-2025, 07:27 AM
  • dmcabs
    SHARP LC-60LE640X display flashing white noise patches and totally dropping out randomly
    by dmcabs
    Hey guys,
    I have a SHARP LC-60LE640X TV that has suddenly developed an intermittent fault of flashing white noise patches (appears like an Analog tuner off signal) and then totally dropping out.
    This model I believe is also known as LC-60LE600U or LC-60LE640U in other regions.
    FYI, a long time ago I was a component level repair tech for all consumer electronics and IT equipment.
    I'm a bit rusty but still have ability to dig right down.
    I measured all power supply lines and checked them for AC ripple voltage. Noting any lines that exceeded about...
    09-21-2024, 11:09 AM
  • dragometin
    Hitachi 40HYC42
    by dragometin
    TV Model: Hitachi 40HYC42
    Power Supply: 17IPS71
    MainBoard: 17MB95M
    Panel: VES400UNDS-2D-NO3
    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
    Is there any variants on 17IPS71 power supply's?
    UART output pins 10 and 12 on scart connector:
    Code:
    12:24:04.595
    08-08-2024, 05:53 AM
