Samsung LE40B530 - iR doesn't work
  • yohnsee
    Semi-noob
    • Dec 2017
    • 198
    • Hungary
    I am slowly going crazy over a problem, please help me out, if you can.
    Long story short: I got a LE40B530 that had a mainboard issue. Power supply checked out fine, so I decided to buy a replacement main.
    I bought a mainboard from a local guy, but he told me that this board may not function properly. He is no expert, he removed it from his broken screen set, sold it to someone, who sent him back because it "froze". His tv was also a LE40B530. Only difference is that his mainboard is BN94-02710T, my original was BN94-02710M. For me they look identical, and googling what the difference is between the "T" and "M" did not gave me any results.
    Anyway, I gave it a try. My set turns on, works perfectly fine, until a few minutes pass by, then it doesn't react to the remote controller.
    It receives the signal, the standby led blinks but nothing happens.
    I followed the path of the signal, it goes into a chip named IC3003 (WT61P8) and I believe that the problem is related to this IC. When the tv is on for about 5 minutes, this IC gets warm (it doesn't get hot no matter how long the set is on) and the set no longer responds to the remote. BUT if I cool down this IC, it works again! More strange things are coming: in this state, the power button still works, but not as intended. If I push it, the standby led blinks, that it received the code, then I wait about 2 seconds, and it turns off. But not as it should, because on a normal shutdown it plays a melody. In this case it just turns off. I attached photos of the main and the suspected IC.
    In addition, the set looks to operate fine from the buttons on the side. The buttons are wired to the same IC, but on different pins.
    Any idea, what should I measure? Where should I look for the problem?
    I've tried so far:
    -change the eprom between the 2 boards
    -change this IC between the boards (it got worse)
    Cheers, Janos
    Re: Samsung LE40B530 - iR doesn't work
    If you suspect that the IC failed when it is worm up then you should try usiing freeze spray or canned duster upside down to cool the IC and see what happen.
    You can repeat the problem, correct?
    • yohnsee
      Semi-noob
      • Dec 2017
      • 198
      • Hungary
      Hello budm, thanks for coming by.
      Yes, I may forgot to mention, that I used freeze spray to cool the Ic down, and the remote started to work again. I can repeat it as many times as I want to. This chip has programmable memory, and my fear is that even if I buy one from eBay, I can't get the code written into it.
      Cheers, Janos
      • petehall347
        • Jan 2015
        • 4451
        • United Kingdom
        freeze and download code if programmed one not available
        • yohnsee
          Semi-noob
          • Dec 2017
          • 198
          • Hungary
          Yeah, that crossed my mind too. I have a TL866 at home, unfortunately that can't handle it. I am thinking of getting an other programmer also, but I don't know which.
          Cheers, Janos
          • syaoran123
            • Jun 2014
            • 178
            Can you transfer the chip from your old board across to your new board?
            • yohnsee
              Semi-noob
              • Dec 2017
              • 198
              • Hungary
              Yes, and I already made it twice. The old one refuses to work even sooner. So at this point I think, I may be so unlucky to get 2 ICs with the same problem, OR the problem is on the other part of the board and somehow related to this chip.
              Anyway, I wanted to fix it as soon as possible, so I ordered a 100% working mainboard. I will be very curious, when it arrives, I will make counter measurements, maybe it will tell me what the difference is.
              Cheers, Janos
              • syaoran123
                • Jun 2014
                • 178
                Oh you mentioned you moved the IC across in your original post. Sorry for asking.
                Btw, the Samsungs normally take 2 sec to respond to power off commands on the remote, don't they? And the melody could be set to ON/OFF using the screen menu.
                • yohnsee
                  Semi-noob
                  • Dec 2017
                  • 198
                  • Hungary
                  Yes, you can set the melody. BUT this happens, when it is set to play it. I am not missing or anything, I was just thinking this gets us to locate the problem. I have a feeling, this is some kind of weird issue related to the IC's internals. As I wrote, I have already ordered a working mainboard, but being curious about this problem, also ordered an IC. Will look into it when they arrive. One more addition: having absolutely no other idea, I refreshed the solder joints around this IC. Resistors, capacitors, everything. When I got to the 24MHz crystal, the working time of the set significantly increased. I have never seen a crystal go bad, but at this point, I can imagine everything
                  Cheers, Janos
                    09-07-2024, 05:50 AM
                  • Nairolf
                    Samsung DM32D – Red LED blinks 5 times, won’t start (possible mainboard issue)
                    by Nairolf
                    I have a Samsung DM32D display.
                    When I try to power it on, the red LED blinks 5 times and nothing happens—the unit won’t start.
                    Here’s what I have tried so far:
                    1. Disconnected the cable between the mainboard and the power supply → the backlight turns on.
                    2. Disconnected the main T-CON ribbon cable → same issue as before, the LED still blinks 5 times.
                    3. Disconnected one of the two T-CON ribbons to the panel (tested each one separately) → same issue, the LED blinks 5 times.
                    From these tests, I suspect the problem might be on the mainboard. Could anyone...
                    08-24-2025, 03:47 AM
                  • bohaboha
                    ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                    by bohaboha
                    Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                    04-19-2025, 01:47 PM
                    09-06-2024, 11:40 PM
