[Samsung UE40D5000PW] Horizontal band
  • cicabu72
    • Oct 2016
    • 32
    • Italy
    Good morning everyone, this is my first request here, I really need your help with my Samsung TV LCD UE40D5000PW.
    This the current situation, you can view a dark horizontal band on the top of the screen. Problem has suddenly appeared, TV hasn't been suffering accidental hits, TV was bought in 2016. Panel or T-CON issue?
    Thank you!
    LCD TV details
    https://ibb.co/mRRnKT
    https://ibb.co/g7uUYo
    https://ibb.co/gKLsm8
  • Diah
    • Feb 2013
    • 6366
    Re: [Samsung UE40D5000PW] Horizontal band
    much like T-CON, upload good photo of yours T-CON first
    • budwich
      • Jul 2015
      • 3097
      the dark issue likely suggests a problem with the way the side drivers are being fed (or not). On smaller sets like this, these are usually fed by the lower corner tab on the bottom of the panel. Check that area out. Apply some light pressure on the tab to see if it changes anything in the display (ie. darkness / band goes away).
      • cicabu72
        • Oct 2016
        • 32
        • Italy
        Bigger here: https://image.ibb.co/ejNLOo/DSC_20180730_170708_302.jpg
        I will check if applying pressure changes the problem on the display..
        • Diah
          • Feb 2013
          • 6366
          Ok thanks for the photo, you need first to disconnect one side ribbon cable between T-COO & LCD of the effected side , and tell the result.
          • cicabu72
            • Oct 2016
            • 32
            • Italy
            Is the one at the bottom, correct? What should happen? I'll test in the evening
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              No. not the bottom one. That is the LVDS cable from the Main Bd. The ones that should be removed one side at a time are the top ones. With the set off, remove one side and turn on the TV and observe if the band appears on the half with the picture. Then turn off the TV reconnect the removed side and disconnect/remove the other side. Turn on the TV and observe if the band is present. Report your findings.
              • cicabu72
                • Oct 2016
                • 32
                • Italy
                Sorry for beeing late, here you can find pictures with one cable disconnected at time. Is this problem related to T-CON? I am going to replace it in case! Thank you!
                Bigger pictures here: https://image.ibb.co/hGoJGK/DSC_20180803_125003_742.jpg / https://image.ibb.co/ckYUOz/DSC_20180803_125302_848.jpg
                • Diah
                  • Feb 2013
                  • 6366
                  the effect on the effected side look different as the first post image, and also i can see on the first post the image when you had called the service menu the image became complete with out any issue of the service menu content.. !!
                  please confirm it with service menu image
                  • cicabu72
                    • Oct 2016
                    • 32
                    • Italy
                    Yes it looks different, it's a little bit weird.
                    When I plug both cables while displaying the service menu image, vertical stripes on the left disappear and the image artifact looks similar to my first post (darker image).
                    • Diah
                      • Feb 2013
                      • 6366
                      in service menu make hard reset. check LVDS between MB and T-CON
                      • cicabu72
                        • Oct 2016
                        • 32
                        • Italy
                        Sorry there was a misunderstanding.. the image on the first post displaying service menu (LCD TV details) was a previous one, before the appearance of the problem. I will check.
                        • attainteddragon
                          • Apr 2013
                          • 764
                          • australia
                          as budwich mentioned in post #3, you appear to have a panel fault. most likely unrepairable for this set.
                          WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            T-CON Bds when they go bad or are failing do not manifest their faults with HORIZONTAL lines or symptoms. The symptoms always show as VERTICAL lines. Since most screens now only carry COFs at the top or bottom of the Panel and do not have side Tab Bds are connected to the T-CON Bd via a Source Bd or Tabl Bd you could have applied the bypass method to repair horizontal lines issues. So yes you do have a bad Panel and so this is repairable at a high cost and is not worth the expense.
                              Dead panel, toss it.
                                09-07-2024, 05:50 AM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
                                Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 06:20 PM
