LG 42lv5300 no audio, image ok
  • disorder
    • Sep 2015
    • 156
    • france
    hello,
    i need some help.
    i have to check a tv lg 42lv5300 : no sound and picture ok
    all audio outpout not work : speakers, headphone or optical outpout.
    i checked the voltage on speakers : 10V on the four : spkL+, spkL-, spkR+ and spkR-
    i have resolder the audio amp ic : ntp-7100, the same. i don't think it's faulty cause optical outpout not work too
    i have tried all hdmi inpout, the same
    can someone help me ?
    thank you
  • R_J
    • Jun 2012
    • 9558
    Re: LG 42lv5300 no audio, image ok
    All audio signals seem to come from ic100 LGE3556C, Audio amp ic operates from +24 volts which would explain 10 volts on all speaker pins (aprox half of supply voltage)
    Also headphones use a seperate amp.
    It could be anything including eeprom corruption or some wrong setting in the service menu
    • disorder
      • Sep 2015
      • 156
      • france
      hi,
      i have just reflowed the lge3556c and it works now !!!
      thank you boss !
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Glad you got audio. Thanks for the update.
        • diif
          • Feb 2014
          • 6978
          • England
          I've just had a 47LD790 in with picture but no sound. Also cured with a reflow.
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
          • samson7point1@yahoo.com
            Help troubleshooting an audio problem with an RCA SGT-250 CED Player
            by samson7point1@yahoo.com
            The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
            The player processes the audio signal using two different reference frequencies. The "R"...
            04-30-2024, 11:22 AM
          • Jaime Morillo
            Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
            by Jaime Morillo
            Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
            The TV was stuck on the logo and I couldn't access the update menu.
            I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
            The image result was good, but the image is inverted.
            The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
            Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
            08-18-2025, 11:38 AM
          • i_am_patch
            Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
            by i_am_patch
            Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
            04-30-2024, 08:20 PM
          • ratslap
            Hisense Roku 58R6E3 has back and audio, no image
            by ratslap
            The television screen is black but it is back lit. flashlight test doesn't yield any results as the screen is lit. the television just repeats a message about enabling or disabling the screen reader feature.
            first thing tested was unplugging the screen cables that lead to the tcon. when I unplug the right cable the screen shows half black on the left and white on the right. but when i unplug the the left tcon cable the entire screen remains black. From my understanding this indicates a screen panel problem. I have had previous success with covering some of the...
            01-26-2024, 04:24 PM
