Reboot cycle on Samsung TV: UE 40D (5700)
  • junkpete
    • Jun 2018
    • 14
    Hey guys,
    I hope you help with with my Samsung TV: UE 40D (5700)
    A few days ago when I turned it on, it started to reboot every few seconds. This is the loop cycle:
    • red LED in front blinks a few seconds (display is black)
    • picture appears, sound is playing for about 5 seconds
    • everything turns black and the loop starts again
    I measured a few caps on the PSU but they seem to be fine. Visual inspection also did not reveal anything suspicious.
    When I disconnect the mainboard from the PSU and turn the power on, the background light is constantly on and there is no restart.
    I also disconnected everything else from the mainboard to see if something attached to it is causing trouble, but it makes no difference (reboot all every few seconds).
    I found the schematics of the PSU here: https://www.electronica-pt.com/esque...-00423a-30427/
    But I don't really know where to start the trouble shooting...
    One thing which bugs me is the output connection from the PSU to the main board, where I measure 2.1V on pin 13 and 3.1V on pin 15 (while the mainboard is disconnected), although the printed table says "B5V", which I guess should indicate that it's a 5V rail. See here:
    I also reset the EEPROM (connecting pin 1 and pin 4 under it and turned it on for half minute), but it didn't help. At least this seems to solve similar issues for a few people.
    Any ideas? Is this a bad PSU? But if so, why is the background light working fine when I disconnect the Mainboard? Or is it a firmware issue on the mainboard?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Reboot cycle on Samsung TV: UE 40D (5700)
    When the power supply is connected to the mainboard and you come out of standby do you have 390V across the two legs of CP814S.
    • junkpete
      • Jun 2018
      • 14
      Yes I do! It drops to around 375V when the TV reboots and then comes up to 391V again and stays constant until the backlight is off again (and the reboot happens).
        Did you remove the connector at both ends, one end is connected to the power supply board, the other end is connected to the main board to see if there is any overheated sign on the connectors?
        BTW, if you disconnect the cable between the power supply and the main board, do the backlights stay on when you apply AC to the TV?
        https://www.badcaps.net/forum/showth...897#post838897
        Please let us know if that fixes the problem or not.
        • junkpete
          • Jun 2018
          • 14
          Yes, I removed both also both ends, no overheated sign anywhere.
          Yes, the backlights are then permanently on.
          I found a guy in my home town who sells the chip for 30EUR (https://www.badcaps.net/forum/showth...897#post838897), so I guess I will try that next week.
          Or are there any other thoughts?
            At this point it is the main board problem.
            • andytw
              • Jun 2018
              • 13
              My rebooting Samsung thread....
              https://www.badcaps.net/forum/showthread.php?t=70027
              Andy
              • junkpete
                • Jun 2018
                • 14
                Alright, I replaced the NAND chip by a new one (I managed to get one for 25 Euro) and the TV set has still the same symptoms. I also detached the mainboard and then the lights are permanently on.
                Any ideas what to do next? :-/
                • ARGO
                  • Jul 2018
                  • 31
                  I have 2 Samsungs with reboot problem too.
                  I think the problem can be in WT61P805. Do you have it on your board?
                  • junkpete
                    • Jun 2018
                    • 14
                    Yes, this TV has a WT61P805. OK, so I'll replace that too... I'll report back.
                    • ARGO
                      • Jul 2018
                      • 31
                      You can’t just replace it. It has firmware, you must flash new chip.
                      • dick_barton
                        • Aug 2015
                        • 6642
                        • Wales
                        Are pins 13 & 15 still reading low when the set is powered up and out of standby?
                        • junkpete
                          • Jun 2018
                          • 14
                          Originally posted by ARGO
                          You can't just replace it. It has firmware, you must flash new chip.
                          Damn, I just noticed... I replaced it and now it won't do anything at all when I plug the TV in.
                          Of course the backlight is on when I disconnect the logic board.
                          I don't have any tools to flash it. Is it worth to buy the equipment?
                          • junkpete
                            • Jun 2018
                            • 14
                            I will check that, I just need to reinstall the old chip
                            • viktorkane
                              • Jul 2018
                              • 32
                              • albania
                              hello friend
                              write new dump
                              • viktorkane
                                • Jul 2018
                                • 32
                                • albania
                                HELLO
                                write this dump
                                Mark:Samsung
                                Model:UE40D5700
                                Chassis (main board, components):BN94-04659C
                                More informations: IC901-24C256
                                • junkpete
                                  • Jun 2018
                                  • 14
                                  Is there a cheap device which can write that dump? I only have programmer for 4/8 and 16 pins...
                                  • junkpete
                                    • Jun 2018
                                    • 14
                                    I got a preprogrammed WT61P805 for 10 Euros and swapped that out. I also measured the IC 202 before to check if it regulates to 3.3V and it does (I fed in +5V externally to test it).
                                    So now I am at the beginning... a black screen and no sound (I guess when I reset the main EEPROM, the tuning was reset too).
                                    The current status is:
                                    WT61P805 replaced, IC 202 is OK, main EEPROM reset and also replaced.
                                    Symptoms: red LED blinking for a few seconds, blacklight is on for a few seconds, no picture, no sound and then everything turns off and after a few seconds it repeats.
                                    When I remove the mainboard plug, the backlight is permanently on.
                                    I searched for a working mainboard but all I could find on eBay were refurbishing services which do the same chip replacements.
                                    Or do you have any other ideas?
                                    • viktorkane
                                      • Jul 2018
                                      • 32
                                      • albania
                                      you are an amateur or a professional
                                      we have 35 years of repairing tv and
                                      • junkpete
                                        • Jun 2018
                                        • 14
                                        I am actually a physicist with a decent equipment and a good amount of theoretical understanding (which doesn't help much, haha). I repair all kind of stuff when I find some free time, but I have no professional training, especially not with TVs (this is my first TV project).
                                        I also don't have any deadline since it's my own set
                                        Any hints are welcome.. I am not sure if replacing all kinds of capacitors on the signal board is the way to go now. I could also measure their ESRs but it's quite fiddly and I hope someone with tons of more experience has a good clue where to look next.
                                        • spice_disc
                                          Vizio TV M50-C1 reboot cycle and static on screen
                                          by spice_disc
                                          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                                          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                                          09-08-2024, 02:37 PM
                                          09-07-2024, 05:50 AM
                                        • alltvrepairs
                                          Samsung HG49EE690 Hospitality TV reboot issue Mainboard BN94-11086A
                                          by alltvrepairs
                                          I have 3 of these TVs for repair with same problem of going to standby after around 10minutes and start again continuously. I have tried a new SPI 25Q40 but fault remains. Am suspecting a CPU problem as it gets a bit hotter than I expect.
                                          This seems to be a common problem in these models. I am 100% sure it is a mainboard issue as I have fitted a spare from a normal TV from a UE40K5607 and stays on (diplay inverted but I managed to rotate in SM using a different display).
                                          Any help appreciated!...
                                          03-14-2024, 03:39 AM
                                        • brkie
                                          Samsung UE75TU6905 reboot loop
                                          by brkie
                                          I have a Samsung UE75TU6905 from 2021, with a maximum of 10 hours of usage as it has been used as a presentation TV in the office. It started rebooting, the picture disappears, the sound continues for 2-3 seconds, and then it restarts (Samsung logo with Tizen OS), after which it returns to the previous activity. I tried disconnecting HDMI, antenna, WiFi, and using different power outlets, and it seemed to improve (or so I thought). Before, it happened occasionally, but now it happens all the time, so the TV stays on for a maximum of 30 seconds.
                                          I read on Samsung's website (reviews)...
                                          09-04-2024, 01:45 AM
                                        • bohaboha
                                          ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                                          by bohaboha
                                          Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                                          04-19-2025, 01:47 PM
