Ecco LCD TV Model LC-42 Solarized image
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Good day,
    I have a tv with a heavily solarized image and also on startup the startup logo seems weird with half of the image being a gray and green bar. Check photo attached. I have taken photos of the main and TCON for your perusal.
    I have no customer remote so i am buggered. Would you say its a TCON issue or rather a setting in service mode?
    Regards
    A Anagnostou
  • diif
    • Feb 2014
    • 6978
    • England
    Re: Ecco LCD TV Model LC-42 Solarized image
    I'd suspect the maxim 9668E gamma ic. You can measure/record the voltages at the test points to confirm.
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Hi, which test points are of importance, can you tell me and i will send feedback?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Hopefully this will give you some idea of what voltages to check.
        https://www.badcaps.net/forum/showth...ighlight=gamma
        • diif
          • Feb 2014
          • 6978
          • England
          The test points are marked GMA with a number afterwards, top right in your last photo.
          • angelos
            • Dec 2012
            • 573
            • South Africa
            Thanks for the spread sheet link Dick. Now i can make a more informed decision.
            I will test those voltages and get back to you as soon as i can.
            • angelos
              • Dec 2012
              • 573
              • South Africa
              Hi Guys, on this board was no AVDD but there was a VDD and it was at 16.5V. I entered that into the spread sheet.
              Also the VCOM value was at 28V but the spread sheet say a value between 5 to 10V. I checked around and there was VCOMLFB, VCOMRFB and VCOMR which all measure the same at 6.92V which fits the spread sheet as required.
              Check the spreadsheet with all the info.
              Is this a bad gamma IC?
              Regards
              Angelos
              • diif
                • Feb 2014
                • 6978
                • England
                Yes.
                • angelos
                  • Dec 2012
                  • 573
                  • South Africa
                  Can a setting in service mide cause this?
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    No. Not at all.
                    • angelos
                      • Dec 2012
                      • 573
                      • South Africa
                      Ok, thanks. I will seek for such a chip. Would be a import with a looooooong waiting time.
                        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                        09-12-2024, 02:20 PM
                      • Jaime Morillo
                        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                        by Jaime Morillo
                        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                        The TV was stuck on the logo and I couldn't access the update menu.
                        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                        The image result was good, but the image is inverted.
                        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                        08-18-2025, 11:38 AM
                      • reach7458
                        philips 37pf8404 solarized image (changed as15f already)
                        by reach7458
                        I got here an philips 37pf8404 with a solarized image. image one
                        First guess its a bad as15f. so I replaced it with another. Same issues
                        So I replaced it again with a rm5101. Same issues
                        Problem is that is projecting a solarized image irregularly. When I pull the hdmi cable and put it back all is okay for a undetermined time. It also helps if I change the input from one hdmi port and back.
                        One thing thats weird and I don't remember if it was the case with the previous tvs I repaired.
                        When the image is solarized it doesn't affect...
                        08-03-2020, 08:27 AM
                        HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                        This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                        09-06-2024, 10:56 AM
