Neighbor Was Gonna Junk It.. Back Light Issue..
I Saved Him dump Fees Brought it Home.
Seemed that On Initial Start All the Back Lights Worked then went to only a Strip in the Middle.
Disassemble.. Check Connectors Good..
Turn On With back Off Witness All LED Holes int he Back Light for 3-5 or so Seconds Then Down to Center Only.
Take Voltages
Odd Ball Was On Pin 6 of the LED Connector..
Remove Pin 6 all Other Back Lights Work.. Hook Up pin 6 or that LED Channel /Array down to Just that Strip Working and Knocks out the other 3?
Swap LED's Arrays Again With Pin 6 Hooked Up get a Different Bar Of Working LED's but shuts down the other 3.. Leave The Channel / Array Disconnected and it is Watchable With 3 Channels / Arrays Going.
Looks Like a Little Burn Under QD30 9477 Mosfet? A Used LED Driver Is $20.00 or so on Fee-bay.
Could there be Something in the LED Array that can cause it to fail? I Cannot find a Source for the 9477? Anyone know? Search Mouser, Digikey, Etc.. Surface Mount Soldering and Reflow is Not an Issue I have a Decent Bench. Not in to reworking led drivers so not sure if worth reworking or just replacing with a used one? I am way out of Practice / Knowledge on these modern items hahaha... In any Case will work as a Great Garage/Shop/Security TV to Fill The Cabinet Void.. Wonder If i Could Combine the Strip to another Channel or would it draw to many amps?
My Small Work Bench.
Shop Cabinet Void
Shop Other Side..
Take Voltages
Shop Cabinet Void
Shop Other Side..
