Need help testing an OLED TV | LG 55EC9300
  • Diah
    replied
    Re: Need help testing an OLED TV | LG 55EC9300
    if the test you did exact as i wrote.. the Main boards totally disconnected from power boards and the lvds to T-CON. and apply 12V from power boards socket direct to the T-CON F1 fuse then the result as you said.. its 100% panel but not at cells... you have the issue on the lower edge boards of the panel it could be COF burned or just leaking at ceramic caps too.
  • speter
    replied
    I have run the test, the panel lights good on half(rotating r g b colors), and like the video on the other half, so bad panel or tcon
    After a while it goes to a white screen with black areas
  • Diah
    replied
    Originally posted by speter
    Sounds good! I'll try that
    here the instruction how to let the PSU turned ON with out main boards connected.
  • speter
    replied
  • Diah
    replied
    please read this threat to the end .. i do encourage you do the test i asked the owner to do at post #22.
  • speter
    replied
    When the tv did not stay on with the Power cable removed from the TCON, I disconnected the LVDS cable between the mainboard and TCON also to see if that would work, but no joy.
    It looks like it may be a main board as you sugested.
    It could be like this guy, and be not repairable, as the problems look very similar.
    I really appreciate all your help! Thanks!
    https://www.badcaps.net/forum/showth...light=55ec9300
  • Diah
    replied
    yes this test should be as normal power on and only the 24V disconnected between power boards and t-con.
    I even tried to disconnect both inputs from the TCON without success.
    what do you mean with other both inputs ? LVDS ? please always upload photo to clear what you are doing.
    I noticed there is no heat pad between the cover and "processor" if that is what it is.Is the large chip supposed to have a heat pad?
    this metal cover shield rules not to cool down the IC on T-con. its to protect the boards from external noise magnetic / signal wave..
    if the test you did correct and the set didn't stay on. its much like Main boards issue as i mentioned at my post #7.
  • speter
    replied
    Ok, I think the reason why I didn't get the LED was it was still in protection mode, I never exited the ponly mode, I can try again, now that I can turn the TV on with the regular power button, I'll try again
    Edit:
    no luck, I never see a led light
  • speter
    replied
    No luck there, I have never seen the optical led light on this set, I pushed a small wire in the door to keep it open, I even tried to disconnect both inputs from the TCON without success. I plugged it back together, and the screen no longer lights. i took the cover from the TCON, and there is no obvious problems, but I noticed there is no heat pad between the cover and "processor" if that is what it is.Is the large chip supposed to have a heat pad?
  • Diah
    replied
    Here is a video of what happens, I will perform the test after dinner.
    https://www.dropbox.com/s/ejm84hvc06...0dies.mp4?dl=0
    its look from this video the issue not the panel .. waiting on yours test result i asked before.
  • speter
    replied
    Here is a pic of the instant the TV faults and shuts down from the video.
    I seem to have lost the ability to edit my posts.
  • speter
    replied
  • Diah
    replied
    I'll try. But it will be hard, because it happens for a very short time before tripping out.
    If I disconnect the ribbon for that side of the screen, should the tv work normally if the OLED panel or driver is bad? Can the ribbon be switched left for right?
    Is there any guide or manual on how to use the functions of the service remote?
    NO
    NO
    service RC. you can use it for power it. and the "IN_STOP" it hard reset followed with inter code 0413. EZ_ADJ & IN_START followed with same code 0413 are for changing parameter at the main eeprom this you don't need.
    Try this test. disconnect the 24V socket cable from Power Boards to the T_CON driver boards.. then switch it on see if the set will remain ON but with black screen. you could know that the set ON from the red LED indicator should lit ON at the Optic Audio Input.
  • speter
    replied
  • Diah
    replied
    I bought a service remote, and was able to turn the TV on with the power only button, and for a couple of minutes the screen was looking good, then the right half went distorted and dark, and tripped out. I can turn it on again, but it trips out much faster than the first time.
    When it starts I get a good onscreen display for 30 seconds now. What would the likely problem be? TCON maybe?
    it is helpful if you uploaded photo on the screen behavior. some kind right screen distorted because of the main boards.. some kind of distorted half screen because of the low level edge boards of the panel. so i encourage you to start with edge boards you may find visible causer.
  • speter
    replied
  • speter
    replied
    I have the same TV, I don't see any cracks, and have forced PS_on, and DRV_ON I get all of the voltages including 24v at the TCON, Do the OLED panels light without the motherboard connected? mine does not.
    Does anyone know how to reset the motherboard with the service remote?
  • Pioneerx01
    replied
    IDK, I had a similar model (55EG9100) last year with cracked screen as well. I was able to turn it on, plug the laptop to it and at least get sound from speakers.
  • Andrew F. Ali
    replied
    Once he screen has a fault like crack, etc the TV will go in 'self-protect' mode. The PCBs will be good. So store them for future use.
  • Moreno83
    replied
    The only thing i know is that "Freakafter8" said that the mainboard goes into some kind of protection mode after turning on the defective tv for 5 or 10 times?
    But it indeed does not work anymore when the panel is cracked. Like plasma.
  • bjwhite
    LG 55EC9300 OLED half picture problems
    by bjwhite
    Hello everyone. New member here posting because I have an LG 55EC9300 OLED that recently began to act up. I've done some searches here and the technical breadth of this group seems to be some of the best I've seen on forums anywhere (AVS, etc.) so I thought I would request some additional opinions.
    This TV has worked fine for years but just two weekends ago we came back from a weekend trip to find that the TV's display only seems to half work. Overall, the operation of the TV is as normal--the TV turns on, can stream Netflix, the HDMI input works, the audio works, the menus work,...
    08-17-2020, 10:35 PM
    Some New Preliminary testing of 21700 Tool battery cells to 2.00
    by sam_sam_sam
    I decided to try a new approach to testing unbalanced battery cells with my battery testing machine that has more graph curve information and it looks like if you discharge them to 2.00 volts if the battery voltage does not come back to over 3.something volts you have some kind of issue with that battery cell
    I going to do more testing and see if is the case or not
    More to come later
    05-04-2023, 05:11 AM
  • llonen
    Lg Oled error codes (LG oled 55B9PLA)
    by llonen
    I am going to go and look at a LG oled 55B9PLA television shortly, about the only information I have so far is the set fails to start up and there is two flashes from the power LED. The customer has replaced the power supply board with no changes in sets behaviour, any thoughts please as I rarely work on LG Oled simply because there was not much uptake of this display technology.
    Thanking you in advance
    04-23-2023, 01:42 PM
    I just bought a SkyRc MC3000 battery testing machine very interesting device temp
    by sam_sam_sam
    I just bought this device that came in the mail today I put a set of 4 brand new 21700 high current battery on the charger
    The charger has four individual temperature sensors for each battery cell
    The bar graph for each individual battery cell is very primitive but will give you a good idea of how each battery cell is preforming and I find something odd I put on the individual battery testing machine that gives more details of the charging/discharging curves but it will be quicker to just charge and discharge battery cells that do not have any issues
    Or test...
    09-14-2022, 07:12 PM
  • Scruit
    MOSFET testing question
    by Scruit
    I am testing an NPD603AL (N-Channel Logic Level Enhancement Mode Field Effect Transformer) from an old Comapq Proliant 1500 CPU daughterboard. Symptoms are no post / no video, with only the psu / blackplane / cpu daughterboard and CPU in place.
    First question: This is not explicitly listed in the datasheet title as a MOSFET, however in the description it states it uses D-MOS technology. I assume this means it's just a MOSFET, and the "logic level" means it only needs 5v gate-source charge instead of 10v. Is that correct?
    I am testing this because...
    04-10-2022, 07:50 AM
