Samsung 4k dark areas
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello I have this samsung 4k UN48JU6500GCFV that make a dark area to the right.... any chance it is the backlight or it is the screen?
    Any hint or procedure to try?
    Thanks a lot in advance...
    Marcelo J
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Samsung 4k dark areas
    That looks like a backlight issue to me, at first peep.
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      +1 Agree. Is the image a good image and just a brightness problem, i.e. no image retention on the right hand side.
      • arenat
        • Nov 2015
        • 22
        • Argentina
        Probably panel/t-con issue . Look the backlight in the link.
        https://articulo.mercadolibre.com.ar...un48ju6500-_JM
        • R_J
          • 9588
          I'd be leaning more toward a t-con or panel issue.
          This must be your tv: https://articulo.mercadolibre.com.ar...-a-reparar-_JM
          • budwich
            • Jul 2015
            • 3097
            the vertical "line" would appear to indicate a problem somewhere in the bottom edge board on that side that is potentially loading that side down... assuming that line is not part of this particular video. Is that line always there?
            • marce002
              • May 2018
              • 316
              • Argentine
              So it is imposible to make sure the screen is ok? I wanted to repair unless screen is the problem... i might find electronics spare parts cheap but not the whole screen...
              Marcelo J
              • R_J
                • 9588
                If the t-con board is located near the bottom of the tv, I would suspect either cleaning fluid or water ran down the front and damaged the board that connects between the t-con cables and the panel itself
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  so it might be a panel screen issue?, no way to be 100% sure that swapping parts from another identical tv with broken screen would make it work?..... worth to try?
                  Marcelo J
                  • marce002
                    • May 2018
                    • 316
                    • Argentine
                    also it is a led tv what does t-con board mean here anyway?
                    Marcelo J
                    • R_J
                      • 9588
                      Ok, so if it is a direct led screen, it has NO Backlight. From post #1 " any chance it is the backlight or it is the screen?"
                      It could be a screen fault or led driver/controller has a problem.
                      are these the board that are in the tv? it seems to have a (tcon)
                      • marce002
                        • May 2018
                        • 316
                        • Argentine
                        In the right border i can see a delay / retard in the image flow.. like if new images are refreshing ok in the 90% of the screen but in the right part are some kind of drag or blur observing old images vanishing and mixing with new ones... i can upload a better video if you want but thos 2 would help:
                        https://youtu.be/u9Uaat481Xk
                        https://youtu.be/2ERe1dwS8RY
                        Marcelo J
                        • budwich
                          • Jul 2015
                          • 3097
                          that's likely a sign that tab drivers are in trouble. You need to check the edge boards along the bottom / top of the screen (depending on how this set implemented those board... most are along the bottom... but from the picture, it appears they are along the top... like some sony's). Anyways, I think you are basically "screwed".
                          ITS not a LED screen... its LED backlit... the screen is an LCD based screen.
                          You might get lucky (doubt) but if the edge boards are along the bottom and as mentioned earlier, water or something wet got in there, then that portion of the board might show signs of "fluid ingression"... if lucky you might be able to clean / check to ensure there aren't "contaminations" along the ribbon cables going from the edge board to the screen.... that's almost what your first picture shows.
                          • marce002
                            • May 2018
                            • 316
                            • Argentine
                            Thanks budish..I will take it apart today and will be in touch with plenty of photos for the site just in case another un48ju6500 is in same situation... keep in touch
                            Marcelo J
                            • marce002
                              • May 2018
                              • 316
                              • Argentine
                              I have opened and checked it, all I can say , the panel looks good, pressure over the tabs, connectors and driver bars did nothing, lifting the panel a bit, while tuned on , the backlight seems to be fine, and evenly distributed ... so I do not know what can be wrong.... I do not know if the backlight is so slight in variations I could not see any difference in the right or left side, seemed al the same to me... hiting the screen sometimes made the bright become normal for an instant in certain areas...
                              a video from the same TV DEMO for further analysis of the symptoms:
                              https://www.youtube.com/watch?v=kDzh...ature=youtu.be
                              Marcelo J
                              • marce002
                                • May 2018
                                • 316
                                • Argentine
                                I have just seen a patch at the bottom ...might be indication of something.. also here noticeable dark side at right. Why can the bottom menu be visible if the noise cant in the last picture?
                                Marcelo J
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  Does this have side tabs ? In the last pic you can see a dark horizontal bar at the bottom starting halfway (at the small YouTube writing) going to the right edge.
                                  • marce002
                                    • May 2018
                                    • 316
                                    • Argentine
                                    No side tabs... only bottom edge tabs.... the image is ok only affected by dark area... just and only just want to know if related to panel/driver circuit or related to the rest of its electronics....
                                    Marcelo J
                                    • budwich
                                      • Jul 2015
                                      • 3097
                                      its a tab problem. When you say there are no side tabs... are you looking from the back or the front of the screen. Sets that have no side edge boards like the bottom, usually on have tabs on the side which run from the panel back to the back, basically interconnecting and driving the side of the panel. The last bottom tab on the corner provides powering and signal to those via the panel. The reason that the panel is dark, is because for whatever reason, those side tabs are not be driven, but they are loading down the drivers of the other side, hence you see the darkness.
                                      Further, the bottom corner tab has more problems which you are now seeing as "marks".
                                      It is highly unlikely that there is any way to fix this. At best, you could try removing the side tabs which my get rid of the darkness on that side. The uniformity across the screen will be better but not 100% because of the loss of the tab drivers leaving only the opposite side to drive the screen.
                                      • marce002
                                        • May 2018
                                        • 316
                                        • Argentine
                                        when i took it apart i saw a lot of tabs unconnected on the sides and i though they were not used from factory, now i realise someone unconnected them to achieve what you say budwich... poor observation on me
                                        Marcelo J
                                          09-07-2024, 05:50 AM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
                                          Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                                          This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-06-2024, 06:20 PM
