Lc-70le600u
  • Hoeinc
    • Apr 2014
    • 18
    Lc-70le600u
    We are trying to figure out why this Sharp LC-70LE600U tv won't turn on. No standby led or seem to have a standby power. We've replaced the power supply and it has the same reading as the old one. It acts like it's turned on as soon as you plug it in, but when you try and turn it off no change from reading in power supply. Thanks for any ideas!
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Lc-70le600u
    Hello Mike and Brian at House of Electronics in Bolivar, how are you today?
    They call me......."threadkiller"
    • Hoeinc
      • Apr 2014
      • 18
      Re: Lc-70le600u
      Well, thank you. And you?
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        Re: Lc-70le600u
        Just finer than a frog's hair split 50 different directions!
        600 or 6600U?
        • Hoeinc
          • Apr 2014
          • 18
          Re: Lc-70le600u
          Lol. It is the 600U. Double checked to make sure.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            Re: Lc-70le600u
            Only reason I asked is I have a lc-70c6600u on the bench right now.
            So are you ever going to get me those pictures/model numbers?
            • DXseekerMO
              • Feb 2018
              • 1119
              • US
              Re: Lc-70le600u
              Oh and did you try the "ignore errors" power on?
              • Hoeinc
                • Apr 2014
                • 18
                Re: Lc-70le600u
                I see. I think sometime when he can get them all pulled out he will try and get some shots. Not familar with the "ignore errors." So, no, we didn't try that. Lol.
                • DXseekerMO
                  • Feb 2018
                  • 1119
                  • US
                  Re: Lc-70le600u
                  Unplug the TV
                  Hold "volume up" and 'Channel down" buttons simultaneously while plugging in the TV. Keep them pressed for 5-10sec
                  See if it powers on
                  • Hoeinc
                    • Apr 2014
                    • 18
                    Re: Lc-70le600u
                    Unfortunately, no change; did leave the new power supply installed.
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      Re: Lc-70le600u
                      Regular buttons on the side or EZ touch buttons in the front bezel?
                      • DXseekerMO
                        • Feb 2018
                        • 1119
                        • US
                        Re: Lc-70le600u
                        Let me put it this way:
                        EZ touch buttons: Simultaneously press power, input and volume down. I don't think you have to unplug then hold buttons and plug in on these.
                        Regular buttons: Unplug TV, simultaneously press input and volume down while plugging in the TV.
                        Does it power on?
                        • Hoeinc
                          • Apr 2014
                          • 18
                          Re: Lc-70le600u
                          Sorry, got tied up. Didn't mean to abandon the post. Used the buttons on the side of the tv.
                          • DXseekerMO
                            • Feb 2018
                            • 1119
                            • US
                            Re: Lc-70le600u
                            Were you able to get it to start?
                            • Hoeinc
                              • Apr 2014
                              • 18
                              Re: Lc-70le600u
                              No. Same as before.
                              • Hoeinc
                                • Apr 2014
                                • 18
                                Re: Lc-70le600u
                                If anyone has anymore ideas, please, let us know. We would like to try and fix this tv.
                                • tvguy12012012120
                                  by tvguy12012012120
                                  02-07-2025, 05:13 PM
                                • fharris1977
                                  Vizio D50u-D1 Dead Set No Standby
                                  by fharris1977
                                  Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                  12-28-2023, 10:25 AM
                                • Crystaleyes
                                  Samsung BN44-00259A standby question
                                  by Crystaleyes
                                  Hi all.
                                  I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                  SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                  Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                  The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                  08-11-2023, 05:15 AM
                                • psssst
                                  Yamaha TSX 120 Standby Problem
                                  by psssst
                                  Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                  03-01-2024, 07:25 AM
                                • reessi
                                  JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                  by reessi
                                  I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                  You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                  Years ago it had some bulging caps...
                                  04-26-2021, 11:42 AM
