What glue for led covers?
  • Newbie123
    • Oct 2015
    • 58
    • uk
    Hi all was just wondering what glue people use to glue back on the led backlight covers/reflectors (think thats what they are called) when they fall off?,obvs im worried about using anything that may burn with heat..Thanks in advance.
  • diif
    • Feb 2014
    • 6978
    • England
    Re: What glue for led covers?
    5 second fix. UV curable clear glue.
    • Newbie123
      • Oct 2015
      • 58
      • uk
      Thanks Diif,much appreciated.
      • Newbie123
        • Oct 2015
        • 58
        • uk
        What brand of glue do you use?,thanks.
        • petehall347
          • Jan 2015
          • 4448
          like glass bond ?
          • diif
            • Feb 2014
            • 6978
            • England
            It's just called "5 second fix" ebay has plenty of listings. Costs between £2.35 and £3
            • Newbie123
              • Oct 2015
              • 58
              • uk
              Thanks diif,being solvent free and liquid plastic thats a good shout,high temp resistance as well much better than superglue and epoxy,thanks for the advice.
              • SLK001
                • May 2014
                • 264
                I use 5 minute epoxy. Gives you a chance to properly center the lens over the LED prior to setup.
                • mmartell
                  • Oct 2013
                  • 3189
                  I use heatsink glue. Doesn't set instantly and you can't beat its thermal properties
                  • Chungalin
                    • Jul 2014
                    • 423
                    • Spain
                    I’ve used Cyanoacrylate (Superglue3, etc.) for this purpose. Some complain that its vapors can bleach the lens or LED. The trick here is to use only the exact amout of glue, just a tiny drop in the 3 spots that lens attaches to the strip. Anyone has had issues with this glue? I’m about to fix a LG 42LB650V with plenty of detached lenses and I have to be sure there won’t be long term problems (heat related, for instance).
