Sharp LC-20AV1U
  • NxB
    • Feb 2009
    • 1595
    Sharp LC-20AV1U
    I have a sharp LCD tv that makes a high pitch squeal when plugged in. The relay on the inverter also clicks. I replaced a zener diode that had continuity and now it tries to start up. It still squeals but it clicks less. The diode also glows and I assume will burn if I leave it going. I have no way to tell the value of the diode so I replaced it with one that was similar. Any ideas?
  • PlainBill
    • Feb 2009
    • 7034
    Re: Sharp LC-20AV1U
    A glowing diode is a bad sign. Similar?? What was your criteria? A 5.2V 500mw zener is similar to a 5.1V 350 mw zener and can probably be used as a substitute. Just because two zeners are supplied in the DO-5 package doesn't mean they are similar.
    I'd say the proper starting point would be to find a service manual, or at least a schematic.
    PlainBill
    • Toasty
      • Jul 2007
      • 4171
      Re: Sharp LC-20AV1U
      >>makes a high pitch squeal when plugged in<<
      Just sitting there, not turned on it squeals? Does it turn on? Any picture or OSD?
      >>The diode also glows and I assume will burn if I leave it going<<
      If it glows, either you have an LED there or it's already burnt.
      >>replaced a zener diode that had continuity<<
      Do you mean shorted? It read the same when you connected it both ways *out of circuit* on the ohmmeter?
      What are the numbers on the original?
      Toast
      veritas odium parit
      • NxB
        • Feb 2009
        • 1595
        Re: Sharp LC-20AV1U
        Can't measure the dead one. No markings other than 8.
        • NxB
          • Feb 2009
          • 1595
          Re: Sharp LC-20AV1U
          When you plug it in, the status light starts up amber and the squealing starts.
          • Toasty
            • Jul 2007
            • 4171
            Re: Sharp LC-20AV1U
            >>Can't measure the dead one. No markings other than 8.<<
            Huh? How did you arrive at the "continuity" statement then?
            veritas odium parit
            • NxB
              • Feb 2009
              • 1595
              Re: Sharp LC-20AV1U
              DMM beeps, both ways. Completely shorted. I took one leg up because I know diodes can seem blown in circuit, it still did the same thing. I thought I found another one on the hot side but that one worked once I pulled one side up.
              • PlainBill
                • Feb 2009
                • 7034
                Re: Sharp LC-20AV1U
                Good job of testing. I suspect the replacement is an incorrect part.
                Does this particular set have an internal power supply, or does it have an external 'power brick'?
                PlainBill
                • Wizard
                  • Mar 2008
                  • 2296
                  Re: Sharp LC-20AV1U
                  Also measure the output side of the diode (one leg lifted) to the ground with mainboard connected and screwed to the chassis to make sure there is no shorts. Shorted load kills diode.
                  Cheers, Wizard
                  • NxB
                    • Feb 2009
                    • 1595
                    Re: Sharp LC-20AV1U
                    Internal power supply. Will check the other diode that measured dead in circuit to chassis ground and the one that keeps getting burnt. I wish there was some way to check the value of this thing. It could just be the value is too low or its another short somewhere. All of the ICs in the inverter test fine too as do the ones in the power supply. Any way to tell if the transformers are screwed up or shorted?
                    • PlainBill
                      • Feb 2009
                      • 7034
                      Re: Sharp LC-20AV1U
                      A ring tester may tell you that. I'm a little vague on just where this diode is. Is it part of the power supply? One trick I have used is to hook up a variable power supply to each of the outputs of the power supply. If you can successfully output 1-2 volts into each output it's pretty certain there is no major short.
                      As far as determining the value of the shorted diode, the schematic (or parts list) is the best bet. The other approach is to analyze the circuit to see just what it does. At least we can be certain it's no x-ray protection diode.
                      PlainBill
                      • Toasty
                        • Jul 2007
                        • 4171
                        Re: Sharp LC-20AV1U
                        What makes you think it is a zener diode? Where is it located?
                        If in fact it is, then the 8 means most likely it's an 8 or 8.1 volt zener. Current capacity can be guesstimated by diameter and length.
                        Check the caps coming off the cathode end (banded end) in the circuit. See what voltage ratings they have. May lend a clue to determining value also.
                        Pics of:
                        1) the original diode with some size reference (ruler)
                        2) the problem area and surrounding components
                        3) pics of the circuit trace side of the board
                        Depending on what area this is in, the high pitched squeal and the burning of the diode could be due to a HV capacitor, probably ceramic or poly, that may be open or shorted.
                        It also may be a Schottky type diode that is typically used in switching power supplies and in the horizontal section of TV's. It needs to be capable of high speed switching. A regular diode can't switch fast enough and will exhibit the overheating you're seeing.
                        Hmm. More I think about this, if you saw a symbol on the board that looks like a zener, you may actually have a Schottky. The 2 are VERY similar and can be confusing.
                        Look here at symbols:
                        http://en.wikipedia.org/wiki/Zener_diode
                        http://en.wikipedia.org/wiki/Schottky_diode
                        Toast
                        veritas odium parit
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          Re: Sharp LC-20AV1U
                          It's very possible that the reason the original diode blew is from an overload on the PSU or through one of it's outputs.
                          Maybe a shorted inverter driver transistor drawing too much current from the PSU?
                          As for the zeners value the best way to find it out is shell out a few bucks for the service manual that way you won't just be guessing.
                          When I'm working if I can't find one for free with a bit of Goggling I can get it for under 12 bucks.
                          No doubt it will also make tracing out the circuit and troubleshooting easier.
                          I have also traced many singing inductors or transformers to high ESR caps in circuit with them so you should check that out too.
                          As for the ring tester it's about 46 bucks from Anatek unassembled unless you're constantly probing electronics like I am it's pretty pricey. But like my ESR meter I would never give it up.
                          • fzabkar
                            • Mar 2009
                            • 772
                            Re: Sharp LC-20AV1U
                            LC-13AV1U | LC-15AV1U | LC-20AV1U Operation Manual:
                            "... models are different in size and shape, but operate identically."
                            Since the one user manual covers all three models above, then maybe the service manuals are similar ???
                            Here are some possible candidates:
                            sharp lc13_15b4e LCD Colour tv part1:
                            http://www.eserviceinfo.com/download...c13-15b4e.html
                            sharp lc13_15b4e LCD Colour tv part2:
                            SHARP LC15B2EA Part 1:
                            http://www.eserviceinfo.com/download.php?fileid=15413
                            SHARP LC15B2EA Part 2:
                            http://www.eserviceinfo.com/download.php?fileid=15414
                            SHARP LC15B2EA Part 3:
                            http://www.eserviceinfo.com/download.php?fileid=15415
                            Sharp LC-30HV4E (19MB):
                            Here is an extensive parts list for your model:
                            http://bestbuy.partsearch.com/Model/.../LC20AV1U.aspx
                            A search for "diode" finds 16 candidates.
                            • unimatrix93
                              TV backlight zener diode
                              by unimatrix93
                              Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                              So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                              Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                              The led strips has 9 6V leds.
                              02-10-2025, 12:13 PM
                              NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                              I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                              I bought this from an eBay seller but unfortunately they only had one
                              I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                              I bought three of from them to also make battery packs with this output power limit in mind
                              I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                              04-23-2025, 05:50 AM
                            • nev1001
                              What zener diode might fix the sound on Maestro Mayhem gaming chair?
                              by nev1001
                              Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                              The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                              It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                              I think an issue could be a zener diode (or capacitor) which has shorted out.
                              The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                              04-17-2025, 05:09 PM
                            • Vincenzo2
                              Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                              by Vincenzo2
                              My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                              Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                              I put some pictures here to show that it is labeled "M7"....
                              09-07-2023, 07:43 PM
                            • hobostove
                              Corsair RM1000e - Help identify 5VSB Zener diode
                              by hobostove
                              Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                              Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                              There's a 22ohm resistor that's melted and open, but it still has the bands.
                              The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                              It looks like the diode connects the source and drain of a TNY284...
                              03-27-2025, 02:25 PM
