CRT coolant change and prevent clouding?
  • Wizard
    • Mar 2008
    • 2296
    Hi all, I have been doing some coolant fluid changes in the CRT projectors for awhile but I really want to do it better. Fewer dust flecks, and prevent re-infection/clouding issues from re-ocurring. Reason I have to do this for two reasons was cloudy coolant or repair leaks which either way had to disassemble CRT assemblies.
    I find it hard to get all flecks out of CRT even I swished out empty, washed CRT coolant resealed chambers with fresh 99% alcohol.
    Also is there better disinfectant than alcohol? Cannot use acetone because of C-lens are comprised of plastic. The C-lens is first lens mounted on the CRT assembly and sealed with o-ring. (bowl-shaped lens coated with antiglare/x-ray).
    Cheers, Wizard
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: CRT coolant change and prevent clouding?
    dont use alcohol!
    it kills some lenses and the colored coatings.causes surface crazing and loss of some coatings esp green on nap sets.
    i wash the crt face and lense assy in very hot water with a touch of chlorox in the final rinse which is very hot distilled water.
    when it dries due to the heat no spots.
    never had any more clouding or floaters on any i did.
    i did get some bad coolant once that had crud in it from new though.
    • Wizard
      • Mar 2008
      • 2296
      Interesting!
      That all? That's interesting. CRT face when I pull out of RCA have TOUGH deposits where rubber seal sits on and takes acetone & swabs to clean off. I do the rubber seal groove as well.
      One note of interest, many of RCA I get had bloated expansion bulb even new (assembly mistake) should had been down position to allow for thermal expansion.
      RCA diaphgrams does not have "flex" design. Simply a cup, hence the frequent leaks if it's up position (bloat). In their natural state removed from the assembly, RCA diaphgram looks like Charlie Chaplin's hat from black and white film (I'm big fan of him for his funny acts).
      http://en.wikipedia.org/wiki/Charlie_Chaplin
      Other projector makers designed their diaphgrams correctly so there is no assembly mistakes except for one or two runs of bad diaphgrams in few brands.
      Cheers, Wizard
      • Krankshaft
        • Jan 2007
        • 2328
        It is also important to use a fine microfiber cloth that way you can wipe and not worry about smudges. I don't have nearly enough patience to wait for air drying.
        Distilled water is a great idea as mentioned too. If there is any remaining dust remove it with a soft brush.
        I had to remove a few dead flies and years of dust when I replaced my convergence amps on my RPTV last April. I figured I'd pull the screen off and see how bad it was. I didn't remove the headgasket though just the lenses.
        What a difference in color the picture seemed much brighter and sharper afterward. It's suprising how much a little dust can effect clarity.
        • ElectricDoodler
          Lenovo Thinkpad X230T Convertible - display assembly and touch digitizer
          by ElectricDoodler
          I need the schematics and boardview for the display assembly and touch digitizer for an X230T convertible tablet from Lenovo. Would anyone happen to have them?
          I have one in perfectly working condition, and I've been primarily using it as a drawing tablet for a while. But the CPU is showing its age with it not being able to handle larger canvases, so I would like to remove the display assembly and use it as a USB drawing tablet, and I need to verify the pin-layouts of the touch digitizer to do so.
          Model: X230T (type 3437-23G)
          Display FRU 04W3919
          Display P/N...
          01-19-2025, 12:57 AM
          Surface Mount Fuses Fundamentals Datasheet
          TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
          TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
          10-07-2024, 06:07 AM
        • SluggerB
          Can't find exact matching caps for replacements, what should I get to prevent video issues?
          by SluggerB
          I have an old Tivo. The Power Supplies are known to have caps that fail. Here are the caps that come with the original power supply:
          I could not find replacement caps with the exact same specs. I followed an online guide and recapped the power supply with caps with these specs
          The power supply now works, however the HDMI video is giving me eye strain. I don't know how a capacitor on a Power supply could impact an HDMI video signal, but it does, the Tivo interface has a flicker now and the color/brightness is off. So I want to get some new caps...
          04-05-2024, 07:47 PM
        • bohaboha
          DO THERE IS A SOLUTION PREVENT MELTING DIFFUSER
          by bohaboha
          I want to find a solution, perhaps an ultimate, solution to this dilemma with your expertise. As it stands, the diffuser is too close, if not directly on the joint, there must be a way to separate without affecting image quality, I'm thinking with small glass strips or maybe pieces that make it a little distance, melan, them, or what do you suggest?
          03-06-2024, 12:59 PM
        • Vinylbeast
          Noble potentiometer assembly
          by Vinylbeast
          I had taken out the pot for my Denon DAP-5500 as it was scratchy and would sometimes drop a channel til I would work it and would come back for few days. Decided I had time today and would just desolder from board and disassemble and clean properly. My only issue is I forgot to take a pic of the orientation of each of the white parts and how they were aligned. Due to the shape of the rod and the cutouts on each white piece they can only go one of two ways. I did have frame of mind right after I took off the first (back) and I know how that last white piece was orientated, note the main shaft is...
          10-08-2023, 02:34 PM
