Samsung UA46F7500 software file need
  • pawan007
    • May 2018
    • 7
    • india
    Sir please help me Samsung model ua46f7500 set
    Restart problem please give me software file link me
  • Citymin
    by Citymin
    S/N : 5RNK9FFT70...
    08-05-2025, 05:12 AM
  • GeckoGreen
    Samsung service bulletin: need firmware file for PN63C550 TV
    by GeckoGreen
    I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
    You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
    The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
    Will you please help me get the [2D63]LOGIC.bin file for my TV?
    05-17-2025, 02:47 PM
  • fulepost@outlook.com
    Samsung "QE" series QE55Q70RATXXC Intermittant restart in "home mode".
    by fulepost@outlook.com
    Dear all.
    I'm a less knowledgable member who would appreciate some guidence.
    I have a Samsung QE55Q70RATXXC that works perfectly in "shop mode" but in home mode it restarts, Intermittantly.
    With intermittant I mean the TV can work perfectly for a week and suddenly start to restart. Before the restart it may reach different stages. Sometimes it restarts when the "QLED" start screen shows up and some thimes it restarts after hours, and everything in between.
    When the restart occurs, the screen blacks out leaving a light area alomng the edges fading...
    11-09-2025, 07:10 AM
  • alex26
    Samsung Qled QE58Q60 restart
    by alex26
    Hello. I have a Samsung qled model QE58Q60TAU.
    The TV restarts continuously and without an image. If I disconnect either half, the TV does not restart, but in both situations I have absolutely nothing on the display, only the backlight is on. I checked the CKv signals and the rest VGH, VSS etc. I measured them against the ground and between them and found between VGH and VSS a resistance of 106 ohms on the B side of the screen (right). I isolated all the signals on the right side and covered them with scotch tape and absolutely nothing has changed, it doesn't restart but I have no picture...
    12-29-2024, 03:12 AM
  • reformatt
    Intel iMacs, 3rd party SSD failures and Fusion setups
    by reformatt
    I thought I'd throw out some of my personal experiences in the last 12 months with Intel iMacs, 2.5" SATA SSD drives and Fusion drive data recoveries.
    As a backgrounder, Apple never fitted a 2.5" SSD's to these iMacs. Apple's SSD option was a system of 32GB NVMe blade drive (NGFF connector) and Seagate 1TB 2.5" HDD, married together in software to become a Fusion drive. Non Fusion systems have just the 1TB Seagate HDD.
    So, the most common reason an iMac comes across my bench is because it's either ridiculously slow, or it fails to boot at all. The most...
    12-18-2024, 10:34 PM
