Lg 42pn5400 won't turn on
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    I haven't been on in a while. I picked up a free lg 42pn5400 that shut off during a storm.
    I had a working psu for it so I swapped it out. Tv won't turn on. Only the red standby light is on.
    I've disconnected the mainboard from the control board and jumped the pins for test patterns but the screen stays black. No change to the standby led.
    I've forgotten a lot of what I had learned. Any help?
    Could it still be the main board if there are no, test patterns.
  • maxvalutech
    • Dec 2014
    • 804
    • australia
    Re: Lg 42pn5400 won't turn on
    Sounds like y or x problem screen not lit etc you need the voltages check and jumper PSU with main disconnected I.e pson vson to see if screen lights, briefly disconnect y side is vs up on psu . I've got a PJ and a PG in front of me now and yes takes awhile to recall the steps to follow.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Re: Lg 42pn4500 won't turn on
      It's the main board. It wasn't enough to disconnect the lvds cable from the main board to the control board. I disconnected the power cable from the psu to the mainboard.
      Once I did, I got test patterns.
      • maxvalutech
        • Dec 2014
        • 804
        • australia
        Well done. On the PG I only had to take out lvds as otherwise PSU wouldn't start without jumpers. I've got a 60PV with no pic to work on when I manage to wrestle it to the table - more self abuse I think !!!
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • stylishconsultant
          un60j620dafxza - Samsung No Display Problem
          by stylishconsultant
          Hi All,
          Need help.
          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
          09-04-2024, 03:26 AM
        • patricksurry
          Sony Bravia XBR 55X900E cycling through test patterns: which board(s) to replace?
          by patricksurry
          We had a power outage but TV seemed to be working fine afterward. This morning it showed a "grainy" picture, and then next time we turned it on it's stuck in a test-pattern loop. None of the resets I've tried have any effect, including unplug/wait/plug in - it immediately goes into this cycling test pattern.
          Does this suggest the main board needs replaced? The TV is about 5 years old, picture still looks great (tho limiting to crisp red/green/blue/white lacks some variety ...
          04-08-2023, 06:45 AM
        • brzostos
          HP ENVY X360 15-EU0005NA 203037-2 does not turn on, something whistles on the board.
          by brzostos
          Hello, HP laptop model 15-EU0005NA. It does not turn on, 1 in 100 manages to turn it on then after a while it freezes/disappears/flashes, etc.
          After removing the motherboard and connecting the board with RAM to the power supply, I noticed that at first all voltages start correctly and after a few seconds 3.3V on the PL4501 coil disappears and somewhere in this area something starts beeping on the board, sometimes after touching it with a finger in the area of PL4551 it stops beeping and 3.3V appears again.
          Original HP 150W power supply, the diode in the power socket lights...
          10-01-2024, 01:34 AM
