M421VT LED Blinking white led fix
  • ivtec
    • Dec 2008
    • 1967
    Hi guys my Vizio M421VT started Blinking white led like in the video bellow with no picture or backlight ,i though it was faulty ,i made a google search for this issue and found the video bellow that saved me from lots of work to open this tv to find the issue,so if anybody owning this model check out the video fix.I also noticed someone in the link bellow had an issue with this tv,don't know if had to apply to that fault ?
    https://grfilms.net/v-vizio-tv-logo-...zCzZdgbdg.html
    https://www.badcaps.net/forum/showthread.php?t=28199
  • crewdog
    Hp 15-dy2087nr white lights blinking
    by crewdog
    Board DAOP5HMB8F REV F
    Model OPSH
    No bios battery on board
    Power at cord 19.7, swapped cord 19.7V just to test, tested lid switch good
    Plugged in, battery in, charging port light on solid white, press power button, no fan spin, charging connector
    and power on light both blink white, not in sync, battery voltage 12.2 jumps to 13.0 for a second and then back and repeats.
    Not plugged in, battery in, press power button, no fan spin, power on only blinks white until battery removed, battery 12.7 - 12.1 for a second and then back and repeats....
    10-25-2023, 03:08 PM
  • ahmarzo
    Hp 15-cs laptop 5 times dc jack blinking white
    by ahmarzo
    I have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
    First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
    Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
    But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery...
    12-28-2024, 04:46 AM
  • noipi
    DELL INSIPRON 14 No power blinking orange/white
    by noipi
    i have DELL INSIPRON 14 5410 2-IN-1 blinking orange and white when charger connected, i tried to find Boardview or schematics but cannot find. i opened the unit and the motherboard model number is 203071-1 Watchmen that i found written on motherboard. Where should i start because when i press power on, nothing happens. but i checked the main power rails voltages are enabled and the charging for battery LDO is 3.3 volts.
    05-06-2025, 08:08 PM
  • jorpec
    HP Elitebook 8460p battery led white and blinking orange
    by jorpec
    Hello everyone
    I have this Elitebook that wont turn on, only the battery led is white and blinking orange, does this even without battery.
    If this is a error code i couldn't find any info about it.
    Already tested with a another charger, measure the presence on 19v on the 19v rail, checked if there was capacitors in short-circuit
    Thanks...
    05-05-2025, 04:39 AM
  • jajo17
    HP Probook 470 G2 - white blinking - ADP_SIGNAL ?
    by jajo17
    Hello, I have this laptop with a bad motherboard. The LED in the socket is blinking white, endless loop. According to the information I found on the internet, this can be caused by several reasons that I am currently investigating.
    1. Damaged BIOS chip - it seems to be fine, CH341a programmer can read it
    2. BIOS RTC voltage shorted to ground - it seems to be fine, around 3V
    3. Damaged adapter identification circuit - I think there is a problem here, but please help explain the function
    What should be the voltage on ADP_SIGNAL when using a 65W HP adapter? My calculation of the voltage divider comes...
    02-28-2025, 05:18 AM
