Samsung motherboard and part numbers
  • Acca
    • Jul 2017
    • 47
    • Italy
    Hello guys,
    I've this samsung monitor/tv that has multiple problems
    1)it won't accept inputs from the keyboard OR remote
    2)The dvb-t doens't work -tv is used with an external decoder
    About the first issue: this model has 2 boards for the commands, the first one connected to the motherboard only has the On/Off button and the IR receiver, and then there's the second board that has the vol/ch/menu/input keys.
    I tried removing the second board alltogheter, remove only the keys, removing the smd caps from the bus (after I found that the keys and the IR work because I find some volts when I press a key or send an IR command), but nothing.
    So I decided to buy a new board but I can't find the same exact one, the board number is bn41-0088a1 and on the sticker it says bn9401366d and I found boards with the same model but with the sticker code that ends in L or N or X or C but not D.
    In your experience are those compatible with this tv?
  • Acca
    • Jul 2017
    • 47
    • Italy
    Re: Samsung motherboard and part numbers
    I had the opportunity to test a board taken from a 19" with a different barcode and while it turn on the display size is incorrect and can't be changed from the service menu.
    So I guess I can answare my question, it's not compatible.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      What's the model number of your set?
      • Acca
        • Jul 2017
        • 47
        • Italy
        2032mw
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          Can you go through the troubleshooting guide from page 32 onwards.
          Manual available from here. Wait until it says Get Manual
          • ohren
            Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
            by ohren
            I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
            I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
            The models launched in 2018 and 2019 respectively....
            09-08-2023, 05:24 PM
          • C152Heavy
            Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
            by C152Heavy
            Summary for TL-DR readers:
            • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
            • Have obtained Samsung schematic & service documents - Can upload if helpful.
            • Have read ALL applicable threads
            • C1818 and CP820 replaced as low hanging fruit
            • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
            • VCC pin (18) of PFC...
            01-11-2023, 02:53 PM
            09-07-2024, 05:50 AM
          • Nicktronic
            Samsung Power Supply Board BN44-00874F
            by Nicktronic
            Hey everyone,
            This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
            Anybody...
            03-17-2025, 06:20 AM
          • valvashon
            Samsung UN65KU6290F PS board blows fuses
            by valvashon
            Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
            Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
            11-27-2023, 01:09 PM
