Dead Panasonic TH-85PF12E due to fault in AC DET circuit
  • Tim Stinchcombe
    • Apr 2018
    • 5
    My first proper post, mostly of a 'for information' nature, in that it might be of use/interest to others rather than being a call for help, as the problem encountered in our unit has been largely resolved. (A huge thank you to tom66 for this thread, which got me going in the right direction!)
    The unit was sold (for a song) as unworking, having received a suspected large voltage spike during a thunderstorm when it stopped working. On applying power there was no response whatsoever - no relay clicking, no front panel LED, no spinning fans, nothing. Given that there are no schematics available online (well at least not that we could find), it became clear that if we were to find the fault, we would only do so after a good deal of detective work, most likely involving reverse-engineering selected parts of whatever boards as necessary. (There are service manuals available online for both the European model, TH-85PF12E, and the US equivalent, TH-85PF12U, and they do contain half-a-dozen or so block diagrams, but which nevertheless did turn out to be useful. We even contacted Panasonic, but no dice.)
    On removing covers and pulling the power board which is fed from the mains inlet (the P(SUB) board), we immediately spotted an electrolytic cap with the vent split open, which gave us a hope of a really simple fix, but alas on replacing it there was no change in behaviour. Initial attempts to troubleshoot the switching supply on the P(SUB) board were thwarted by my lack of experience with such supplies, but once we established there were five windings on the transformer, and not the four shown on the block diagram, some simple tracing out of the circuit clarified things a good deal, and we were able to establish that the switching IC was alive and well and generating at least the +5V rail sent out all over the place to power many other boards, and a more localised +9V 'biasing' rail.
    It was then we realised we'd probably have to start trying to establish the correct functioning of some of the many error signals and commands coming in/going out to various other boards, something that was likely to involve a deal of guesswork and supposition, as most of these signals are not described or even mentioned in the service manual. It was Googling that led me to the thread mentioned above, and which sowed the idea that closer scrutiny of the 'AC_DET' circuit might be a worthwhile endeavour. I then traced that part of the circuit, which is shown in the attached schematic - that it bore more than a passing resemblance to tom66's diagram was a confidence booster.
    Notes on the schematic:
    - the '0V' node is the negative end of the DC output of a bridge rectifier (D506 on the board)
    - as neutral is basically ground, the circuit relies on this '0V' point out of the bridge being a diode-drop above the negatively-swinging 'live' mains input during the one half-cycle (well it took me a while to get this straight in my head!)
    - the 15V zener at the bottom of the chain is not 'zenering': measurements/calcs show that about half the (peak) voltage of 340V is dropped across the 3x 820k resistors, giving a peak current of around 70uA; this drops about 9V (peak) across the 130k's at the bottom, thus keeping the zener off.
    - the 2SK3018s are SOT-323 packaged and marked 'KN'
    - the 130ks having no marking - 130k is based on DVM readings
    - I've included a few of the actual reference designators on the board on the very small chance someone else really wants to know them
    Not immediately bothering to work out the precise functionality of the caps involved, I guessed the two MOSFETs would keep the PNP continually on, thus giving a 'high' 'AC detected' signal. However on applying the scope to the board (powered-up on the bench), we got 50Hz spikes from the PNP, a looks-like-it-is-working dip at the one MOSFET drain, and nothing from the other. This immediately suggested that one of the MOSFETs wasn't working: the input at the gate on the good transistor was peaking at 9V, the 'bad' one was 200mV at most. So we kludged in a SOT23 2N7002 instead, and discovered we now got 100Hz pulsing at the PNP, which looked encouraging, but it was asymmetric, with 7ms/13ms between pulses. This was because the voltage swing at the 2N7002 gate was only peaking at about 3V (and not 9V as the good one) - whether due to further damage in that locale, or because it is not the correct replacement transistor type (they are on order) we have yet to determine.
    Thinking there was maybe a 20% chance this would allow the TV to run, we replaced the P(SUB) board into the TV and powered up, immediately to get some clicking, a front panel LED, and she is clearly running! An immense feeling of satisfaction I can tell you, as it had taken several weeks and a good deal of head scratching to arrive at this point!
    I have now cobbled together a SPICE simulation of the circuit, using a very idealised 177V zener (!), and found the Rohm 2SK3018 SPICE model on the web, and can now better understand the circuit operation. I have attached a few traces for those that maybe like to see such things (as I do!). I guestimated the value of the caps on the drains at 4.7n, as this visually ties in with what we saw on the scope. Because these charge up quite quickly, this explains the narrow pulses at the PNP collector (feeding the optoisolator LED), which again tie in nicely with the narrow pulses we saw on the scope. (The little glitches in the blue trace are the interaction with the other transistor's switching on the other half-cycle, which I've not plotted.)
    If using a correct 2SK3018 transistor significantly changes the situation I will report so later!
    Tim
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Dead Panasonic TH-85PF12E due to fault in AC DET circuit
    Not sure how the circuit works but if the positive and negative half-cycles charged the capacitors on the gates of the mosfets and turned them on, then if the discharge time-constant of the C*R is much greater than the incoming pulse I would expect both mosfets to switched on and stay on.
    This would then pull the capacitors connected to the drains down to ground. The base voltage of the PNP would be held somewhere around 1/2 supply (if the the capacitors connected to the 9V supply and the two other capacitors connected to the drain of the mosfets were all the same value). The result would be to hold the opto diode on.
    If you lost either of the positive or negative half cycle then the opto would pulse.
    Just my thoughts.
    Edit
    If you short circuit the emitter/collector of the PNP, does your set operate?
    • Tim Stinchcombe
      • Apr 2018
      • 5
      Originally posted by dick_barton
      ... if the discharge time-constant of the C*R is much greater than the incoming pulse I would expect both mosfets to switched on and stay on.
      It turns out the opposite is actually the case. The cap at the drains, which I guessed at around 4.7nF (and as used in the simulation traces), charges through the 22k and the other 22k from the 9V rail to the PNP base; it discharges through both these resistors and the 220k at the drain. This gives time constants of 0.2ms for charge, and 1.2ms for discharge. The latter is easily seen by the upward curve of the blue trace over a handful of milliseconds. The smaller time constant is what gives rise to the short pulses at the PNP collector, because...
      ...the base actually clamps at about half a volt or so below the 9V rail, and as the cap on the drain quickly charges at the short time constant, it isn't long before the base gets pushed back toward the rail, turning the PNP off again.
      We were firmly considering doing that whilst we contemplated what to try next, but as soon as we saw the narrow pulses at 50Hz, and not 100, we realised our assessment that the PNP probably would be held on all the time was erroneous, and then we changed the transistor with all becoming good (or at least, good enough!) so we didn't get around to shorting the PNP out.
      Just my thoughts.
      Appreciated!
      Tim
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        So it's up and running. If so well done.
          Nice - glad you got it working...
          I ended up replacing the module on the P board to fix this issue as it came back after a while... Seemed to be triggered by slightly low mains voltage.
          • Astonished
            Fixing the Charge Circuit of the Batteries of the DC Motor
            by Astonished
            Hi friends of electronics
            What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
            The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
            Please help me fix this circuit.
            (the datasheet of the IC: https://pdf.datasheet.live/28...
            01-28-2025, 06:24 AM
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing hereπŸ€”?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting πŸ˜‚.
            11-20-2024, 08:52 PM
          • chockimon
            Panasonic TX-40AX630B has developed a fault
            by chockimon
            I bought a Panasonic 40" TX-40AX630B TV from Richer Sounds 7 years ago and it has developed a strange fault. If I attempt to press any button on the back of the TV or remote control (access media features etc.) the TV locks up for a few minutes or longer and sometimes goes blank. However, if I turn the TV off and on again and quickly select a channel it will work fine all day long, as long as I don't touch the remote or controls on the back of the TV.
            I've tried changing batteries on the remote, changing plug sockets and doing other things such as a...
            06-02-2022, 12:03 PM
          • Rictech
            Panasonic SA-MAX770PU SMPSU board fault....
            by Rictech
            Hello everyone. πŸ˜€
            As per thread title, this unit has a serious SMPSU fault. It blows F1001, which is a 10A M205 in the phase from the mains input.
            Very first thing I tried, was simply replacing the fuse, but the replacement ceramic fuse blew immediately.
            Looking at the schematic for this PSU, I then removed what I thought was the next likely candidate: D1001 - the HV main bridge rectifier.
            This isolated the fault(no longer blows the main fuse), but does not point me to the actual fault.
            There are no devices that have exploded or otherwise show signs...
            08-26-2024, 01:05 AM
          • CDNBrewer
            Running out of Ideas, hoping someone smart can provide some for my ONKYO TX-SR353 Receiver
            by CDNBrewer
            Hello Everyone,
            I have an Onkyo TX-SR353 Audio/Video Receiver (5.1 ch with HDMI) that I am having a really hard time diagnosing and I'm about to throw this in the junk and go buy a new unit that is on sale until the 7th.
            Symptoms:
            • Intermittent (part of the reason why i'm having a hard time isolating problem), sometimes will work for 10+h at a time without issue
            • Original symptom was wife reported loud banging noise (like someone was banging on the wall with their fists) from the LEFT SURROUND speaker and then the unit shut off.
            • I swapped the Left and Right surround
            08-05-2025, 09:29 PM
