Toshiba 49L621U
  • neilc6
    • Nov 2015
    • 1550
    Re: Toshiba 49L621U
    Originally posted by jostewcrew
    backlight flash on with toshiba logo, then went black with red led flashing 5 times. leds were good
    How did you confirm the LEDs were good? Backlight flash is usually a sign of bad LEDs. Do you have a LED tester? A few of the Toshibas I worked on had bad LEDs that damaged the LED controller on the power supply. The cost of replacing both was close to the value of the TV.
    • jostewcrew
      • Mar 2020
      • 79
      Re: Toshiba 49L621U
      to preface: after reconnecting pin 15 (dim) the set still continues to function properly. any reason? reset, something short close or open? did continuity between the wire at connector insert and the backside of the connector adapter itself to verify its actually back installed.
      1) So what do you have on DIM pin if all cables are put back in place?
      when the unit is off it jumps between 0v and -.1mv
      2) What DCV do yo have on the LED connector of EACH pins when you first turn on the TV (you will need to leave the meter probes in place, black probe on chassis, red probe on each LED connector) and then after 10 seconds then turn the TV off, so you have to repeat this test on each pin of the connector that has the wire connected to it, you also need to provide the pin name so we can easily see what it has or does not have..
      placed in min/max mode: p803 on power board (connector going to led strips)
      with led load:
      pin 1 vled1- = 15.6v
      pin 2 nc
      pin 3 vled2- = 17.1v
      pin 4 nc
      pin 5 vled3- = 15.3v
      pin 6 nc
      pin 7 nc
      pin 8 nc
      pin 9 nc
      pin 10 nc
      pin 11 vled+ = 97.4v
      pin 12 vled+ = 97.1v
      pin 13 vled+ = 97.3v
      without led load:
      pin 1 vled1- = 0v
      pin 2 nc
      pin 3 vled2- = 0v
      pin 4 nc
      pin 5 vled3- = 0v
      pin 6 nc
      pin 7 nc
      pin 8 nc
      pin 9 nc
      pin 10 nc
      pin 11 vled+ = 133.9v
      pin 12 vled+ = 134.3v
      pin 13 vled+ = 131.1v
      • jostewcrew
        • Mar 2020
        • 79
        Re: Toshiba 49L621U
        i first used my backlight tester to test voltages on all 3 strip circuits. they seemed within range of eachother and not off enough to indicate one of the leds went out. i opened it up to visually check each strip after replacing the power board, main board and tcon board without it resolving the issue.
        • jostewcrew
          • Mar 2020
          • 79
          Re: Toshiba 49L621U
          i understand that now with the unit functioning (havnt tested the led dim function as of yet) that some may not want to continue to theorize or such. im learning so im still curious as to why its working now after disconnecting/ reconnecting dim (pin 15)? im assuming its some type of variable resistor ..which i believe would have to be an ic of some sort to be able to increase/ decrease voltage for backlight dimming functionality? budms' insight provided me that it is controlled via the main board...id be interested in figuring out which component that would be and do some testing.
            Re: Toshiba 49L621U
            It is PWM Dimming control. not variable resistor. You do know what PWM is, correct?
            You should check the dimming DCV reading when backlights stay on, it will be average reading since it is PWM not steady DC.
            BTW, LED tester only puts out about 30 mA instead of 200 ~ 300mA of operating current, so using tester will tell you if you have open circuit or not without having to disassemble the LCD panel, not for verify that the LED is good since bad LED will fail at operating current.
            • jostewcrew
              • Mar 2020
              • 79
              Re: Toshiba 49L621U
              i do not sir...link to good reading? iw ill google it after this message. im assuming by abbreviation pwr managmnt chip?
              with the unit on pin 15 (dim) is jumping between 3.005v and 3.024v
              im still familiarizing myself with the tools of the trade. this is good insight on the usage of this device. ive been using it to see only if any voltage reading differs when a circuit of led strips is tested. if they are all lighting and not greater than 3v apart, id say they are good (although sometimes i am unsure of myself so i open up anyway) but if one circuit doesnt light....automatic bulb/circuit failure to me. if one circuit differs between 3v and upwards and the other two are the same...i assume one or more bulbs are out (basing around 3v per bulb)
                Re: Toshiba 49L621U
                https://www.analog.com/en/technical-...d-dimming.html
                https://focuslcds.com/journals/pwm-d...ight-for-lcds/
                "with the unit on pin 15 (dim) is jumping between 3.005v and 3.024v" that is fine.
                What is your TV LCD panel model number?
                • jostewcrew
                  • Mar 2020
                  • 79
                  Re: Toshiba 49L621U
                  pulse width modulator lol....not even close. i guess this is why techs use oscilloscopes? ill research this some more.
                  • jostewcrew
                    • Mar 2020
                    • 79
                    Re: Toshiba 49L621U
                    is this the display unit part number itself? if not then the prefixes...(this may be what youre talking about) is: LTM7UCAR
                      Re: Toshiba 49L621U
                      There should be a sticker right on the back of the LCD panel.
                        Re: Toshiba 49L621U
                        Post # 4 show the LCD panel sticker, since there are more than on revision of this TV we do not know what LCD panel is used in your TV.
                        • jostewcrew
                          • Mar 2020
                          • 79
                          Re: Toshiba 49L621U
                          one sec...going to take a pic it is rev A
                            Re: Toshiba 49L621U
                            You have the same LCD panel as the OP, K490WDR1.
                            I cannot find the spec sheet for this model, the spec sheet will explain what the control signals requirement will be.
                            But at this point you do have reference Voltages of the working condition so just have to make measurement when it stops working.
                            Also try turning down the backlights level (not brightness) to as low as possible in the USER OSD to see if the TV will stay working longer.
                            • jostewcrew
                              • Mar 2020
                              • 79
                              Re: Toshiba 49L621U
                              no problem....for knowledge...what is the search terms you use to find these and what would it mean to me if i had this information?
                                Re: Toshiba 49L621U
                                I just search by model number for the spec sheet.
                                Example of the LCD panel LC500DUE-SFR1 spec sheet.
                                This one tell you the spec and the requirement for driving the LED.s
                                • jostewcrew
                                  • Mar 2020
                                  • 79
                                  Re: Toshiba 49L621U
                                  so that number is pulling up led strips for this model. im assuming the types of leds used ant the voltage requirements per bulb/strip/circuit would dictate the variable adjustment by the pwm?
                                  its obvious i need to start reading up. ty for the help and guidance. if it goes out again, ill know where to start. on a side note: im still curious as to why the new main board did not fix the issue being that its on the main board? or is it just controlled there but a part of something else?
                                    Re: Toshiba 49L621U
                                    See post #75
                                    You need the spec sheet of the panel to know what the LEDs can be driven with.
                                    • jostewcrew
                                      • Mar 2020
                                      • 79
                                      Re: Toshiba 49L621U
                                      ill admit that this is a bit over my head as for now. i will continue to read on this and im sure it will click at my look back at the exapmles given. ty again. last question before i start my own research on all this...... is the pwm hardware driven or software driven? im not sure if im asking this right but is it an operation setting that drives the pwm or is it based on its own creations internal mechanisms?
                                      • jjanssen7
                                        • Nov 2012
                                        • 252
                                        Re: Toshiba 49L621U
                                        I've experienced this model to have a common problem with backlight failure. LEDS come on for between 5 seconds and 5 minutes then BL shuts off but image remains on screen. LED strips test OK with LED tester, but fail under normal load. The way to find the one strip that is failing under load is to test each strip one at a time by plugging in a good know strip in the place of the one being tested. Once you find the failed strip, the BL stay on. (This can be a challenging diagnosis because sometimes two strips are drawing too much current and are causing the BL shutdown!)
                                        Only a matter of time until the next strip fails... I suggest starting with a whole new set.
                                        • jostewcrew
                                          • Mar 2020
                                          • 79
                                          Re: Toshiba 49L621U
                                          so ive read up on pwm and understand quite a bit more...thank you budm and all for the schooling. i still dont know why disconnecting pin 15 (dim solved the issue, other than it bypassed the pwm module...(ic, fet?) dont have the schematic for this to wrap my head around the circuit, but got the main board in based upon your guys' knowledge of the pwm originating from the processor on the board. works like a charm. thanks agian.
                                            09-06-2024, 05:27 AM
                                            09-06-2024, 05:59 AM
                                            09-06-2024, 05:33 AM
