General Question Re: Mylar/Diffuser Sheets
  • Michale32086
    • Nov 2011
    • 1453
    Is there a specific order to the "mylar" sheets that are between the LED array/hard plastic diffuser sheet and the display panel??
    I have a 50" TV that I had to replace an LED strip.. Due to wind, the thin mylar sheets blew off and I have no idea what the original order was..
    IN this case, I have 2 silver/mirrored mylar sheets and a translucent white sheet..
    Not sure how to put them back on the TV...
  • Michale32086
    • Nov 2011
    • 1453
    Re: General Question Re: Mylar/Diffuser Sheets
    More to the point, do those mylar sheets (sans the hard plastic diffuser) serve any really vital purpose??
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • V3dran
      Diffuser/LPG for UE50NU7022KXXH
      by V3dran
      I'm trying to repair a UE50NU7022KXXH with a cracked diffuser/lpg and now also with burned leds
      There are 4/5 white spots on the bottom that are not visible since the left side is dark now so I want to change the diffuser/lpg
      Looking the samsung spare parts, I see that there is a DIFFUSER PLATE and a LPG so I'm wondering what is really broken?
      https://www.samsungparts.eu/samsung-...n61-15659a.htm DIFFUSER PLATE 1125x625x2,5mm
      https://www.samsungparts.eu/samsung-...n61-15661a.htm LPG 1101x619x2,7mm...
      06-26-2025, 01:54 AM
    • repair-it
      Diffuser Sheet ripple
      by repair-it
      I purchased a 43" LG 4k TV last year that was discounted due to damage. The diffuser has a mild ripple in it at the top of the screen. It is a bit annoying. I'm not sure if I can use mild/low heat (iron on a flat surface) to fix it, I'm sure these panels are made using heat but I don't want to add to the problem. I'd also like to know of a resource that sell replacements, if anyone knows of one. This is the very top translucent sheet that is right behind the LED panel.
      thanks,
      rich
      07-26-2022, 09:35 PM
    • David Stroe
      AOC CQ27G2U/BK - in need of data sheets
      by David Stroe
      I am trying to repair my monitor that shows image but the backlight is not turning on. I think either the power supply is not working properly or the LED strip is failing, which seems unlikely (the whole strip is off).
      I really need help in finding the data sheets for this monitor's boards. The data sheets I need are for the following boards:
      Power Supply: 715GA907-P03-000-001S and 715GA721-P01-000-0H4K
      Main Board: 715G9500-M0C-B00-005K
      T-CON Board: 19Y_270_EU3MQ_SR_V02_HF
      If someone could please provide any of these data sheets, it would be awesome....
      05-31-2025, 11:12 AM
    • Topcat
      Nihon Kohden (Tyco Electric) ET2400LM 24" Restoration
      by Topcat
      This was rescued from a recycle gaylord from a hospital along with some other things....
      I don't have to explain the significance of restoring this; 16:10 Aspect Ratio, 1920x1200; very high end Samsung LTM240CT04 panel. Add in it's blonde (will pair nice with a retro rig) and also ELO touchscreen. It is very well made, very heavy. Even used these are hard to find and expensive....but it had some problems...
      Problem one, the external PSU was missing. I found one in my stash that had the correct voltage (12V) with the goofy 4-pin plug it used. It however was light on the...
      08-02-2023, 10:07 PM
