Sony KDL-40W600B blank backlit screen with sound
  • triplefour
    • May 2014
    • 1747
    Re: Sony KDL-40W600B blank backlit screen with sound
    sorry i had to go through a move during which this got put in storage somewhere. i will one day get back to it. thanks for all the help. i havent given up yet.
    Don't fear the repair...
    • neilc6
      • Nov 2015
      • 1550
      Have same model with backlights and no picture. There was low resistance across CD3-6. Removed them all and since I was past the Digikey cutoff time, I replaced with 2 22uf caps salvaged from a scrap tcon board.
      Bit tricky to get at the board since part of the bracket was blocking the shield so you need to disassemble all the boards plus a mounting bracket.
      Thanks budm for the fix.
      • Audeze
        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
        by Audeze
        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
        Does...
        10-06-2024, 08:54 PM
      • mecha1166
        KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
        by mecha1166
        KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
        11-25-2024, 05:22 PM
      • mrtek
        Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
        by mrtek
        Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
        11-26-2024, 09:58 AM
      • salvatore22
        Sony KD-55XE8505 black screen with sound
        by salvatore22
        Hello everyone…I hope someone can help me to figure out…i have a sony tv which the screen is black but i can hear the sound …so I try in another similar tv a t-con , motherboard and all works perfect but in this tv i see only a black screen with illumination…the display is not broken ..so I think the problem is on the buffer board …someone can help me? Thanks in advance
        10-31-2023, 09:30 AM
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
