Philips 40PFL3208H/12 flipped screen
  • loskonsitos
    • Mar 2018
    • poland
    Hello! I have a 40PFL3208H/12 TV, week ago it stopped working and TCON board was a problem so i've exchanged it. Problem is that i put a TCON from 42PFL3108H/12 because i have it on stock.
    Now it's working but screen is inverted, upside down. I've read a lot of manuals, tried to fix it in service menu, changed all the option codes for the correct ones but it's still inverted and i'm stucked right now. I can't find which option could lead for the desired settings. Is it even possible to fix it in that way in this tv?
    Huuuuge request for help guys. If anyone knows anything that might solve the problem, please reply. Thanks
  • ronelex
    • Oct 2016
    • 195
    • Philippines
    Re: Philips 40PFL3208H/12 flipped screen
    I think you can try flashed the eeprom in the new tcon from the data from your old tcon? That is only an idea, I have never tested it goodluck
    • loskonsitos
      • Mar 2018
      • poland
      Thanks, i think i should try that. I've tried to put 062598 + Menu + XXX code, but i've used wrong one (163) and now it's on showing backlight and no reaction to RC. Any idea how to turn it back to the last state? Tried to do software update but no reaction.
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • bohaboha
        PHILIPS 75PUS7805/12 BLACK SCREEN
        by bohaboha
        Hi all this set power on and the ambient lamps lite but the screen is black and no sound i tried Samsung way to test backlight but it did not work i did also try to power of and hold power for some times nothing happened
        on power supply big capacitor :394v on tcon the 12v and 3,3v even on Mainboard...
        08-10-2025, 09:04 PM
