Alright, this is going to be lengthy to a degree, as I'm pretty stumped since I haven't been able to find a solution after sifting through the forums for the last 2 weeks for what's happening. Here's the backstory.,,
Picked this up a couple of weeks ago on CL with a "burn in" band on the top, supposedly from the dad watching a bit too much MSNBC (you'll see it in some of the ghosting). As I was loading it into the car, he threw in a, "Oh, and it liked to turn off about every 2 hours..." After getting it home, I plugged it in and it powered on, although there were quite a few horizontal lines (about 2-4" in length) of black that slowly filled in for the first minute or so as the tv warmed up. After that, I noticed that quite a few pixels were out, but would sometimes light with some colors, or slowly fill in with others (I'll have a video link below).
Deciding to see how long it would run before turning off, I found 2 hours was closer to 20 minutes, at which point it would hang a moment, turn off and immediately back on. If I ran it from there, it would pretty much do the same thing. Only once was I able to get it to do it twice in 5 minutes, which was then followed by the 20 minute cycle.
I have checked all voltages. None were very far off, but I dialed them in anyway (only Vs, Va, and Vsc are adjustable... Ve can be checked). No change. I tweaked the Vs and Vsc about 5vdc each way, but again, with no major changes.
I pulled the SMPS to check caps and transistors and look for cold solder joints. I cleaned up some suspicious joints, and replaced 2 caps that were "underperforming" (they were at the low end of the tolerance spectrum), but again, no difference in the overall performance. All the IGBT's are working well.
I pulled the Y-sus to check caps and IGBT's, and nothing popped out at me, although I'll admit I simply used my Fluke to check capacitance and for shorts on the IGBT's. While that was out, I did a quick y-buffer check and didn't "hear" any shorts.
I pulled the X-main to check all the usual, and found nothing out of the ordinary.
I did the logic board test pattern (I used the proper procedure for the integrated logic/main board on this set), and will post the pics below, as well as a video to show a small section of the screen which may help someone identify what is going on.
Heck, I even brought home a thermal imager from work to see if I could locate any oddly hot spots on the boards, and apart from places I would think should be hot, only the logic/main looked odd (although it may be normal for all I know).
Like I said, since it is "working", I'm having a hell of a time finding the problem. I would rather not spend lots of $$ swapping boards out, as they're not the cheapest for this set, although I'm just about ready to get a Y-sus w/buffer and x-main just t see what happens...
I'll post some pics here, and in the next post, since I don't think they'll all fit.
lol!
