LN32A450C1D No Power Blowing Fuses Fixed
  • neilc6
    • Nov 2015
    • 1550
    This TV has a BN44-00214A power supply used in several models and there are lots of posts on it. Will start a new one here. Thought it was going to be an easy cap replacement.
    TV had no standby power and a bulged CM858 680uF/25. After replacing the cap, there was still no power and I noticed the main 6.2A fuse was blown. I replaced it with a 8A, plugged it in and sparks flew.
    The blue ceramic cap by the big filter cap had one leg blown out as well as a jumper beside it. The big Samwa filter cap was also bulged (not sure if it was bulged before). A little research indicated the dried out, brownish glue had become conductive causing more shorts. I replaced the big cap with a used one from another board, replaced the jumper and resoldered the ceramic cap (tester said it was still ok). I scraped off all the glue the best I could. Salvaged another 6.2A ceramic fuse and tried a second time. No sparks but still no power and it appeared the fuse blew a second time.
    Did a bit of more investigating using clues from other posts and repair kits. Checking the bridge rectifier, there was a dead short between the + and - output pins which was traced back to a shorted QP801S (FCPF11N60 600V/10A). ICB801S (STR-A6159) could have been potentially damaged from the short but the fuse blowing could have protected it.
    I replaced QP801S temporarily with a 2SK3326 (500V 10A) from another board and the TV finally powered up.
    The ICL resistor is cracked (DSC_5D15) but measures 15 ohms instead of expected 5 ohm so I will need to replace this. Will order the correct FET but doesn't seem that 600V is necessary for the PFC since 400V is expected and 500V should provide enough headroom. I also forgot to install the old ferrite bead that was on the drain pin.
  • BunnyFooFooSR
    • May 2018
    Re: LN32A450C1D No Power Blowing Fuses Fixed
    The blue ceramic cap by the big filter cap had one leg blown out as well as a jumper beside it. Was a fighter tho soldered it from knee to hip back in and replaced jumper and fixed a couple of bad joints. All said and done working and in good order.
    Another dump Freebie!
    • comptek
      • Aug 2013
      • 606
      Remove the glue from the start up transistor too bottom left hand corner with the big cap at the top in fact remove all components with the glue on clean off and replace it will fail again otherwise
        How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
        by sam_sam_sam
        About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
        Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
        1970 Metal Lathe Control Circuit blowing fuses on the 120 volt section failing meager test below 60 mega ohms
        by sam_sam_sam
        I was working on this machine yesterday and I now going to use an incandescent lights instead of a fuses to figure out what the issue is with it blowing control voltage rail but this not the only issue the coolant pump failed the meager test as well as the main motor as well this motor has 12 motor wire leads instead of the normal 9 wires
        This metal lathe has a weird motor setup it has a soft start motor with a “Y” and a delta type of motor winding setup and it is not done in the motor pucker head enclosure it is with four different contactors wired in a configuration I have not...
        12-29-2024, 07:18 AM
      • mon2
        Gemsound PAX-105 Audio Amp blowing fuses
        by mon2
        Hi. New to this side of the forum.
        Have an audio amp (Gemsound PXA-105) that keeps blowing the 3A fuses upon power up. Owner stated that the amp was on when he plugged in the input (mixer board) and that started this chaos.
        Would a schematic be available? Advice on what to check? Power supply / output amp transistors? Do see the power on green led turn on for a brief moment before the fuse blows.
        Thanks.
        10-30-2024, 08:33 AM
        Surface Mount Fuses Fundamentals Datasheet
        TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
        TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...
        10-07-2024, 06:07 AM
      • clearchris
        OWON SPE 6103 Blowing Fuses Roasted Diode
        by clearchris
        This was a great little power supply, until it let out the smoke.
        I believe it's the output diode (pic of mayhem attached).
        Could I remove the diode, power it up (no load) and see if the rest of the PS is functional? Right now it pops the fuse every time.
        Also, does anyone have a diode that they like better than this one? (ER2004CT)
        https://www.panjit.com.tw/upload/dat...0CT_SERIES.pdf
        If anyone wants to know more about this power supply there's a pretty good teardown video here https://www.youtube.com/watch?v=bRWdQESwXMA...
        12-01-2024, 02:12 PM
