Samsung PN50B650S1F clicks on plug-in with flashing voltages
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Hello everyone, my name is Steve and I'm new to the forum. My TV is a 2009 Samsung 50 inch plasma model no. PN50B650S1F. I looked here and other places on the net and I didn't see this specific issue, so before I throw parts at it I was hoping for some good advice. My experience level repairing TV's/electronics is best classified as “beginner”. I can take good quality pictures/video if we need them.
    Before service observations:
    1) Upon plugging in the unit a click-click is heard, then about a second later another click-click. Television does not come on and intro chime is not heard. This continues as long as the unit is plugged in.
    2) The red light on the front of the TV comes on when plugged in and remains on until the unit is unplugged regardless of noises heard.
    3) The remote has no effect on the TV whatsoever, batteries checked.
    4) There are no overheating smells or smoke coming from the unit
    5) Outwardly the unit is clean and in excellent condition.
    Removed back cover:
    1) Unit was very dusty inside with dust bridges between the solder legs of many components. No evidence of water/liquid intrusion was found.
    2) Upon plugging in the unit, the red light on the front of the TV illuminates continuously and a click-click is heard. The green LED number 2001 on the control board flashes twice in rapid succession then LED 2000 flashes on for about 1/20sec then 1/10sec. Another click-click is heard. This sequence lasts for about a second and repeats until the unit is unplugged.
    3) Disconnected both X and Y boards from the power board. Unit still continues to cycle as above.
    4) CAPS were visually inspected on the power board and have no outward signs of failure.
    5) Board was inspected. No overtly hot spots were seen and all solder joints appear solid. The board has a slightly tan/brown appearance on the green printed circuit side near the long brown heat sink, on the lower voltage side of the power board. This heat sink looks like it has 7 MOSFETS on it.
    6) The click-click is coming from a relay at location RL801S.
    7) When the unit is plugged in, after the first click-click, standby voltage (spec 5.3v) comes up to 5.23v, Vs (208v) and Va (56v) reach specified voltage. After the second click-click the standby voltage immediately drops to zero while Vs and Va trail off slowly. This sequence repeats until the unit is unplugged.
    8) One HDMI port on the input board is loose. A couple wires are broken and sticking out.
    The troubleshooting guide I used says to replace the power board and re-test. My preference is not to replace parts blindly but test and troubleshoot as best I can then replace what is needed. I have a DVOM but nothing to check the CAPS accurately and I can unsolder/solder components on a board. I have a soldering iron but no other specialty soldering equipment.
    Thanks everyone for any help or advice!
    They call me......."threadkiller"
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Samsung PN50B650S1F clicks on plug-in with flashing voltages
    It could be a bad mainboard(where the hdmi ports are). I know the "A" series have a problem that is fixed with a 10 cent capacitor at C102 on the back of the main, but I dont know if yours has it. Somebody with more knowledge will step in.
    • freakaftr8
      • Oct 2012
      • 3743
      This model is known for having faulty solder connections on the mosfet transistors that are located along the aluminum heat sinks on the power supply.
      I would suggest re soldering all connections od components mounted to the aluminum heat syncs.
      • DXseekerMO
        • Feb 2018
        • 1119
        • US
        Check the solder points and re-solder as needed or do them all? Re-flow or wick out and re-solder?
        Speaking of those mosfets, I checked one at the center and right leg and it was zero ohms, shorted? I'd like to know for sure how to test the mosfets in-circuit if anyone could tell me how to do that?
        • freakaftr8
          • Oct 2012
          • 3743
          0 Ω shorted? Is this component represented with a Q designator? I would say if it is a mosfet and not a diode and that would be your problem. If so you could replace the recommended parts or just go for a new power supply. Shoddy soldering usually if not caught in time we'll short mosfets.
          • DXseekerMO
            • Feb 2018
            • 1119
            • US
            It is a diode. Just checked.
            Do you think I should check the solder points and re-solder as needed or do them all? Should I re-flow or wick out and re-solder?
            Do the defective solder joints have a circular bullseye crack around the mounting leg of the components? This board has several of them, but the legs don't move. They seem solidly mounted.
            Thanks for the help!
            • tvtimmy
              • Mar 2015
              • 1160
              • usa
              A bullseye crack is bad. When the board heats up it expands and a short can happen. Just reflow everything that is mounted to a heatsink and whatever looks bad. Use lead solder, no need to wick it out.
              • DXseekerMO
                • Feb 2018
                • 1119
                • US
                OK cook I will do just that. Thanks for the help everyone. So just heat the old solder and solder over it with new? It's probably a novice question but that best describes my experience level.
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  Yes.
                  • DXseekerMO
                    • Feb 2018
                    • 1119
                    • US
                    Thank you! Soldering iron is warming up.......
                    • DXseekerMO
                      • Feb 2018
                      • 1119
                      • US
                      It looks like the re-flow did not change anything.
                      • DXseekerMO
                        • Feb 2018
                        • 1119
                        • US
                        I also unplugged all the ribbon cables from the logic board. No change. Any ideas where to go next anyone? Thanks
                        • tvtimmy
                          • Mar 2015
                          • 1160
                          • usa
                          Ok, plug everything back in. Then unplug the cable going to the control board from the mainboard and take a small clip or something to short pins 3 & 4 on control board. Plug in tv and look for test patterns on screen. If you have them the mainboard is bad.
                          • tvtimmy
                            • Mar 2015
                            • 1160
                            • usa
                            The parts in red.
                            • DXseekerMO
                              • Feb 2018
                              • 1119
                              • US
                              Re-solder? The circles surround multiple components, are you talking about the ribbon connections? Thanks!
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                Circle on the left is the ribbon to unplug. Top circle has 4 pins. You have to short them together temporarily to test. You can use a piece of wire and wedge it in between pins 3 and 4.
                                • DXseekerMO
                                  • Feb 2018
                                  • 1119
                                  • US
                                  OK great I will try that and let you know what happens. Seems like we're testing the logic and input boards. I may have the names of those wrong?
                                  • tvtimmy
                                    • Mar 2015
                                    • 1160
                                    • usa
                                    mainboard has all the hdmi ports on it. Logic control board is the pic with the red circles.
                                    • DXseekerMO
                                      • Feb 2018
                                      • 1119
                                      • US
                                      Ok cool. Thanks for straightening me out on that. Kinda need to know the right names for this stuff.
                                      • DXseekerMO
                                        • Feb 2018
                                        • 1119
                                        • US
                                        Okay disconnected that ribbon cable, shorted pins 3 and 4 together with an alligator clip, plugged it in and no change. So are we going to disconnect a different cable, short the other two pins to check another board? Just guessin'
                                        • ngml
                                          Repair of an LG split AC system indoor unit PCB
                                          by ngml
                                          I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                                          This indicates an error in the communication between the outdoor and the indoor unit.
                                          The outdoor unit is fine, so the problem is the indoor PCB.
                                          The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                                          I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                                          Does anybody have the schematics of this board,...
                                          02-01-2025, 12:55 PM
                                        • nobbnobb1
                                          Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                                          by nobbnobb1
                                          Hi guys,
                                          Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                                          When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                                          02-03-2022, 11:14 AM
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • Gjackson
                                          Air-conditioning unit power supply failing to power up
                                          by Gjackson
                                          Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                                          01-08-2022, 09:24 AM
                                        • navagator
                                          Hitachi Power Supply Unit Interchangeability
                                          by navagator
                                          I have a Hitachi 57F710E rear projection set with a bad power supply board. I've tried to fix it with help from this forum as well as another one, but without success. Today I found a Hitachi rear projection set for sale on Facebook that looked just like mine. After contacting the seller I found out it was a 51F510. According to the service manuals my set uses a HA01312, POWER UNIT DP4X-DM_24W and the 51F510 uses a HA01313, U901, POWER UNIT DP4X_24W.
                                          Does anyone know if these 2 power supply boards are interchangeable?
                                          Thanks.
                                          01-08-2024, 07:53 PM
