Have a LG 42PJ350 that has all PSB voltages after 2 clicks. The 15V that is generated from the YSUS bd comes up to 18v and then slowly drops down to 4.1V. The 5V from the PSB is there solid - also on the Ysus bd to the logic bd. Have checked buffer bd, Ysus bd, Zsus bd, logic bd, PSB. Have replaced Ysus bd, PSB, buffer bd, logic bd, and no luck. Remote works good - set turns on and off. When first turned on - set makes a buzzing noise for about 3 seconds (same amount of time the 15V line is around 18.1v). anybody seen this symptom ? About ready to dump this set.
42pj350 all voltages - no display
Re: 42pj350 all voltages - no display
So are you saying the following voltages are good
VS/VA/VSC etc ??
Are you sure the replacement ysus board is good ?Last edited by sordids999; 02-15-2018, 05:32 PM.Comment
ill check again but all voltages are good. Ysus is from ebay who guaranteed bd was good (had a display screen with lines in it), turned on set in dark and noticed the screen shows a 2 mm vertical line at the far right side about 6 inches long on the very edge of the display (near Zsus bd). only stays on the same amount of time the V15 line is good (2 seconds). going to change SMPS now again and try it. test patterns does same thing. new SMPS - same thing
measured VS = 205V, Va = 60.1V, Vsc = 7V
on Ysus bd - 15FL with ground on floating ground off buffer bd is 0.1V, 15FL is 0 V
starting to believe my panel is bad or crackedLast edited by ajshoe; 02-15-2018, 05:53 PM.Comment
+1. Check buffer boards for shorts. Unplug both buffers in check VSCDid I leave the soldering iron on?Comment
I'm still thinking your have a problem with the ysus or even the buffer boardComment
I highly doubt that's the issue I have three Ysus boards they all do the same thing. One of the Ysus boards i bought was brand new. I have two sets of buffer boards that have been checked thoroughly. Any of those boards put in there give me the exact same results.Comment
HI!
Just read many posts related to this TV and mine was like:
Sound and everything works but no image. Voltages on the panel are correct and 15V has 18V ok. Looking for the control board and the led don't light up, so with the set working, i tried to put some pressure in control board XD IC and suddenly the led on ctrl board started blinking and image appeared. I must assume this is a ctrl board with bad XD IC bga joints and it should be replaced.
This is only another testemonial to confirm that when you have all voltages and no image it must be ctrl board fault.
Regards and thanks for all the sharing!Comment
Hi
Yes , your quite possibly looking at poor ball connections on B G A chip .
Unless you have a re-ball station , a replacement control board is required.
Also , normally there is some sort of blink code with L E D S on control board , that may give indication of faulty board , for future reference .
Regards X e n.Comment
by ledbylightHi all!
This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more, and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
11-04-2024, 06:36 PM -
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 7 5800H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Nitro Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060 6G, 15.6" FHD IPS 144Hz Display, Windows 10, Black) boardview and Nitro 5 AN515-45 - (AMD Ryzen 5 5600H, 8 GB, 512GB PCIe NVMe SSD, NVIDIA GeForce RTX 3060...09-06-2024, 10:20 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...09-06-2024, 09:30 PM
This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Silver) schematic. Our...09-06-2024, 09:30 PM
- Loading...
