Toshiba 40L3433DG No back light
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Got a Toshiba 40L3433DG LED TV with no backlight
    This has a Vestel 17IPS20 PSU
    When the TV starts up I get 125V between the output to the LEDs and chassis ground, this then goes up to 190V or so then gradually comes back down to 125V but no backlights
    However when I measure between LED +ve and -ve leads (as opposed to +ve and chassis ground) I get no voltage which would suggest to me that the LED driver chip is open circuit between the LED return and ground which connects via an internal FET I think.
    So I then connected an LED back light tester and the back lights do actually work (I also get a picture on screen) but the back light tester voltage goes all over the place and the LED back lights brightness flickers especially when the voltage jumps down. That would suggest to me there is a problem with the LED strips somewhere. I've uploaded a video of this but it's not easy to see the back light flicker, just the tester voltage behaving strangely. Basically the backlights come on at about 140V then the voltage keeps climbing to over 200V, the lights flicker and hte voltage jumps back down to about 125V and the process repeats either immediately or after several seconds of stable voltage.
    I've not seen this before. Can anyone with more experience of these testers advise on where the problem is? Driver or LED chain?
    video
    https://youtu.be/CR7BEJPoxTI
    Follow me on YouTube
    Learn Electronics Repair
  • zomi
    • Nov 2011
    • 505
    Re: Toshiba 40L3433DG No back light
    check the connections between led strip connector
    maybe oxidised
      You either have bad LEDs and bad connection on the LED string.
        Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
        This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
        I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
        I am comparing them to a brand new one that I installed
        The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
        I going to let it run for several days before I remount back on the wall next to the...
        09-05-2024, 06:48 PM
        09-06-2024, 05:27 AM
      • PNI E.
        tcl u65x9006 back light on but no picture sounf ok after 40 50 secs
        by PNI E.
        hi guys, i need your help again...i have tcl u65x9006. while i was watching it become darker like when a movie ends, little by little the image disappear. now if i turn on i have back light on, after like 1 min i have also sound but no picuture. the back light is on i take off one at time the ldvs but nothing change always no picture. i tried to cover with a piece of paper the pin of ldvs i cover like 7 8 pins but nothing worked. the tv stay with no picture. there is a tcon board.i checked the voltage there on the fuse i have 11,8 volts. there is caps in shorts on the exit of the tcon i have...
        02-20-2025, 08:36 AM
        09-06-2024, 05:59 AM
