information for LED not lit
  • necatduman
    • Feb 2015
    • 72
    • siirt
    led tv on the panel LEDs on the fire will change everything else if you do not have to change your burning LED tekmi to do what you need to do for the sony vestel beko led tv
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: information for LED not lit
    I could not tell from the picture if the backlight LEDs are working. So what do you have? TV goes ON and stay, ON but the backlight do not work? What is the Make and Model Np. of your TV? Could you post pictures of the back of your TV with the back cover removed? and clear focused pictures of the PSU so we could see the labels on all the connectors?
    • necatduman
      • Feb 2015
      • 72
      • siirt
      The master LEDs are working but I do not have the new leds but they are lit after 4 months what should we do for long time not to burn
      • maxvalutech
        • Dec 2014
        • 804
        • australia
        Are we talking about turning down the backlights say to 50% or less?
          • 31185
          the translator software is terrible.
          • freakaftr8
            • Oct 2012
            • 3743
            I believe what he is saying is the power LED lights up but the led's behind the panel are not coming on. Or they come on for a brief second and turn off.
            Hes wanting to know how to test the led's to see if that is a problem. I would go with the digital Volt meter in diode check mode and check each LED individually.
            • necatduman
              • Feb 2015
              • 72
              • siirt
              Thank you for not doing more than 50 back light so LED life is prolonged
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                What make and Model TV is this???
                • necatduman
                  • Feb 2015
                  • 72
                  • siirt
                  Beko arçelİk vestel sunny
                  • freakaftr8
                    • Oct 2012
                    • 3743
                    Sony uses vestel crap?? Oh boy
                    • Pipolups
                      Corsair K70 LUX RGB dying LEDs
                      by Pipolups
                      Hi there !
                      I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                      Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                      10-08-2024, 11:58 AM
                    • nick4275
                      Vestel Based JVC no picture, leds on
                      by nick4275
                      Hoping someone has troden this path before !
                      I'm looking at a JVC LT-39c790 - a vestel based unit.
                      So, the remote turns it on, led's light up but no picture at all.
                      I have a spare mainboard, so I know its not that. The PSU seems ok too.
                      On the AUO T-Con I've got 16v on HAVDD_H but nothing on HAVDD_L - which I'm assuming should also be 16v ?
                      So, Ive resorted to testing eveything I can on the board as I can't find any schemas for it (AUO 39T15 C04 Ctrl Bd) and I think I've found a diode gone short. it marked D005 on the board and E1 on the package...
                      11-21-2023, 04:43 AM
                    • Jaime Morillo
                      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                      by Jaime Morillo
                      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                      The TV was stuck on the logo and I couldn't access the update menu.
                      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                      The image result was good, but the image is inverted.
                      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                      08-18-2025, 11:38 AM
                    • ryogadan78
                      iMac A1418 - No LED, no power after overvoltage on Ethernet port
                      by ryogadan78
                      Hi guys, I need your help again.
                      I have this iMac from a customer that shut down during a storm along with all the other devices in the house. In particular, the router, connected via Ethernet to the iMac, caught fire.
                      When I removed the screen from the iMac to check the status of the LEDs, I noticed that none of them were lit. I had a perfectly compatible and working power supply, so I tried it right away, but the problem remained the same (no LEDs). With the thermal camera, I noticed only a slight warming (32 degrees) of the NCP1605BG chip on the power supply. The rest was completely...
                      06-10-2025, 03:49 AM
                    • France_53
                      Vestel tv, how to flip the image?
                      by France_53
                      Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
                      05-12-2024, 05:22 AM
