Re: Samsung UE32EH5000 backlight issue fix
What kind of voltage did you get on your D+ wire? I unplugged my main board and still no backlights. I get 425v on the D+ wire which drops to 400v when I unplug the main board, and drops again to 292v when I reconnect the main board.
@Dannyx You're post gives me a glimpse of hope. I just acquired a 60" Samsung UN60FH6003 yesterday that has no backlights. I've checked in the dark and can see the picture on screen. When I first turn it on the standby light flashes 6 times. There is no flicker, flash, or visible attempt at the backlights coming on. I've been preparing my mind for the chore of replacing burned out leds, which feels almost worth it considering I got the tv for free. Does my issue sound relevant to yours enough that perhaps the fix is the same? I would much rather replace a cap on the board than pull the panel apart, hands down, any day!Leave a comment:
I was wondering why your English is so good Dannyx...Leave a comment:
Mine was a Samwha too. Makes me wonder why they fail at the legs in this particular setup while normally they'd bulge...the way heat moves around a cap also influences its failure mode from what I know.Leave a comment:
It's good, my friend. You're Dannyx and that's your style. I enjoy your 'novels'. I'm sure it does take a lot of patience to write them, though.Leave a comment:
This is very interesting. Your commentaries are usually very, very long and very, very informative. I like take two days sometimes to read your posts. I will look at this e-cap and similar e-caps on LED Driver circuits in future. Could a faulty/weak e-cap cause repeat failure of backlights, even though the backlight setting was turned down, would be something I will investigate. Thanks again for the share and enjoyed it as always.Leave a comment:
Good day folks. Thought I'd report my findings on another one of these Samsung tellies and how I managed to fix it, so let me tell you a story firstThe reason I'm doing this is because it seems to be a fairly common occurrence, having encountered it myself and read about it a lot now, so I thought I'd add another one to that pile to perhaps same someone out there some time and effort. The first time I ran into this, I got stumped a lot before finally figuring it out, with a little help from our wonderful chaps here of course. I thought the issue might've been a one-off sort-of deal and didn't make a big deal out of it back then, but then I saw it happening again....and again...then read a post here of someone else who was struggling with it and managed to fix it "together" the same way. Here's the original post
The backlight wasn't coming on....yeey. Now it may not sound like anything special and your first thought will be a bad backlight LED, mine was too of course, but they all checked out fine - exactly the same scenario as everybody else having this issue. To make a long story short, the problem is the power supply itself: it's a BN44-00493B in this case, but I imagine it can happen to other similar supplies as well, despite not having seen it myself, at least not yet.
Even though you may be getting something out of the LED connector, like 160v, the LEDs still refuse to turn on, not even a flash or anything, and that's because of a faulty cap, CM867. Now here's the interesting bit which is bound to screw a lot of people over, me included: no visible signs of failure on this cap, so without an ESR meter you might look at it and think, nope, this one looks fine - leave it alone and move on...that was until, on a whim, I decided to pull it out and replace it anyway, since I had just about exhausted every other possibility at this point, including replacing the SLC1012C IC, checking and rechecking all resistors, even SMD ones and every last voltage on there. Turns out it WAS faulty: it had leaked through one of its legs, so that was the issue: I replaced it and I was all good do go.
Now the same thing happened just as I'm writing this, so this being like the 4th time seeing this, I thought I just HAVE to write about itMy buddy had already opened up the TV and checked the LEDs for me, but of course he got stumped the same way I did and had no idea what to check next, being at wits' end. After having a look myself, not trying to be cocky or anything, I went straight to that cap, pulled it out and lo and behold: failed leg once again, except unlike the last time where the leg was fine but the electrolyte spewed out and wasn't particularly obvious unless you got in really close with a magnifier, this leg had completely broken off, showing signs of corrosion. Replacing it instantly fixed the issue, so this goes to show that capacitors can fail even without showing it...which is nothing new, but larger ones like these usually tend to bulge, so you might disregard it initially thinking it's fine, when in reality it's leaked through the BOTTOM instead. In this case at least it's the exact same capacitor with the exact same issue, so it's particularly interesting and strange at the same time. Cheers guys
Tags: None
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by vincentedelHello,
I'm having an issue with the Samsung 740n's phase control setting. When I use the automatic adjustment, it sets the value to around 54 (with a range of 0-100), and the picture looks clear and sharp. However, after some time—like after playing a game—the text starts to look blurry. When I auto-adjust again, it may increase the value to 80, and everything becomes sharp once more. Yet, after a while, whether it's a few hours or a day later, the same blurriness returns, and I have to adjust it again.
I'm using the Samsung 740n monitor drivers instead of the default plug-and-play...-
by ManucslHello.
My TV is a QE65Q800TATXXC Samsung TV.
Issue : When you plug the 220V, voltages are OK on the power board and you can hear the click from the relay, but TV is not starting when power button is pressed. Red led is blinking when you press power button. But no images or sound ( Back-light is off )
Then if you disconnect the cable from the main board to the power supply, the TV back-light turns on.
Any ideas to check would be very appreciated 😊
After reading some posts on this forum, I suspect an eeprom issue so I bought a CH341A to dump... -
by FourRunnerI purchased a used Samsung TV model UA65JS9000W recently knowing it had an issue with the screen. When switched on the picture was bright both sides of the screen but a little darker in the middle of the screen. Thinking this was the back lights (side mounted LCD strips) I replaced these, however the issue is still there. I am now thinking it may be a TCOM issue, but am not sure, any advice on this would be appreciated. Also whilst changing out the back lights I noticed the the thick clear plastic sheet (maybe 1.5 to 2mm thick) below the diffusers there is cracking (up to 75mm) on the sides and...1 Photo
This specification for the Samsung Galaxy Book Ion NP950XCJ Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ boardview and NP950XCJ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 11:40 PM
- Loading...
