LG 42LB5610 BackLight problem.
  • HellasTechn1
    • Sep 2015
    • 176
    • Greece
    Good day to all !!!
    Dear friends, i am now working on this LG 42LB5610 TV. When powered on everything looks normal but about 15 - 30 minutes later the backlight will shut down. Audio can be heared and the panel will display picture. Only the LED's shut down.
    After i turn it off and then back on it does the same thing (works for a while etc...)
    I am thinking that the led strips are fine since they do work even for 15-30 minutes.
    Could you please provide me with guidelines to troubleshoot this problem like for example what measurements i should take ?
    Thank you all so much !
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: LG 42LB5610 BackLight problem.
    Do you still have the Backlight On and DIM voltage when the backlights go off?
    • HellasTechn1
      • Sep 2015
      • 176
      • Greece
      I have not taken any measurements while it is happening. So here is a start
      I do need to identify the correct connector and pins for that first.
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        The other place to measure when you lose the backlights is at the led connector to see if the voltage has risen above what it says on the power supply circuit board. If that's the case then it would be looking like a led or led string connection problem.
        • HellasTechn1
          • Sep 2015
          • 176
          • Greece
          Ok. i have the readings.
          With the TV turned on and while the backlight went off the connector reads the following:
          Pin marking - reading
          12V - 11.85V
          24V - 24.10V
          3.5V - 3.51V
          PWR-ON - 3.31V
          DEV-ON - 3.05V
          P-DIM - 2.63V
          Then i attached the leads of the dmm set to DCV, to the led power connector and i turned of the TV and back on to try to read the voltage with the leds on but after i turned it off and back on the backlight never came on.
          Now it does not turn on at all.
          could it be a shorted led situation ?
          • HellasTechn1
            • Sep 2015
            • 176
            • Greece
            Also i noticed that now that the leds do not come on, the DMM set to DCV will not give me a steady reading but instead it changes rapidly. when i set it to ACV it reads 0.22V .
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              With the meter set to DC volts and black lead on the chassis can you measure the voltages on the led connector again.
              • HellasTechn1
                • Sep 2015
                • 176
                • Greece
                Before i read your last post i tried leaving it unpluged for a while and now it came back to the initial problem.
                The led connector measures 180V when the leds are on.
                • HellasTechn1
                  • Sep 2015
                  • 176
                  • Greece
                  What do you think about the measurements ? PWR-ON and P-DIM look ok to me.
                  What is DEV-ON ?
                    DEV-ON = BL-ON.
                    You have all the correct control Voltages.
                    "The led connector measures 180V when the leds are on." So the backlights are on now?
                      "I am thinking that the led strips are fine since they do work even for 15-30 minutes. " Turn down the backlights level (not brightness) to as low as you can to see if the backlights will stay on longer.
                      • tw2005
                        • Oct 2011
                        • 6458
                        The chances are the LED strips are failing. Simply they burn out so I suspect as the strip heats up one is shorting. Affects a large % of LG LED TVs around this era of all sizes. I've had them simply not illuminate, illuminate briefly or repeatedly blink. The other issue is the lenses fall off.
                        They get to about 3 years and die but I've had examples with only 6000hrs and upwards. Most are 8000 - 10000hrs when they die.
                        Also I've tired using Super Glue (cyanoacrylate) and with the clear lenses the fumes leave a smoky residue affecting the light dispersion which is noticeable.
                        • tw2005
                          • Oct 2011
                          • 6458
                          These are the style of strips
                          LC420DUE FG
                          • HellasTechn1
                            • Sep 2015
                            • 176
                            • Greece
                            The latest sitrep is that the backlight does not stay on that long. they shut down within 1-2 minutes. i will try changing brightness to see.
                            Assuming that the psu is good and some led overheats and shorts, then how will i be able to locate it ?
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              What I do is put on nice dark sunglasses in keeping eye on the led's. What it full capacity one may flicker meaning it's about to die out or a bad SMD soldering job. K this will throw power supply into a tizzy And eventually will shut down because of it.
                              Also you could have an overheating LED control circuits on the power supply
                                "The latest sitrep is that the backlight does not stay on that long. they shut down within 1-2 minutes" Do you have video source connected? Did the TV actually go into standby after 2 minutes due to no video present?
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  This is why I never throw the screen and diffusers back in the TV until I let the LED strips run and burn in for about 2 hours. I've made that mistake before.
                                  This allows me to check heat dissipations and any occurrences that may happen before the panel goes back in and TV goes back in operation
                                  • HellasTechn1
                                    • Sep 2015
                                    • 176
                                    • Greece
                                    Yes video source is on (aerial antenna) and the tv will not go to standby after the backlight turns of (audio and controls work normally).
                                    • HellasTechn1
                                      • Sep 2015
                                      • 176
                                      • Greece
                                      sounds like a good practice.
                                      • HellasTechn1
                                        • Sep 2015
                                        • 176
                                        • Greece
                                        i will try dimming the leds as much as possible like budm suggested after i get the remote control. For now i have tested the voltage to leds from power up untill they turn off.
                                        Voltage at powerup went from 0V to 180V stays like that for about 30 seconts and then slowly droped to 175V - 173V untill it reached 155 volts where it spiked to 180V and then went 0V and leds turned off.
                                        I think, since its a constant current source then i guess the voltage drop is probably to compensate for exess current draw, untill it reaches the lowest possible voltage (or highest possible current) and then shuts down.
                                        Any thoughts ?
                                        • Dobrowol
                                          Asus GA402RK keyboard and kb backlight problem
                                          by Dobrowol
                                          Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                          04-28-2025, 04:30 PM
                                        • ononos
                                          LG M2362DP Backlight problem
                                          by ononos
                                          hello everyone!
                                          As the title states i am an owner of an LG flatron M2362DP 23 inch monitor Tv. Since i currently use it as a tv i'm posting the problem on the "troubleshooting tvs and video sources" section.
                                          I'm from Greece so English isn't my native language, so please forgive me for any mistakes i make. I have basic knowledge in electronics, and although i have a degree, many things have changed since i finished a 2 year coarse (over 30 years ago). Occasionally i repair easy stuff, mostly things that break at home like appliances.
                                          So i decided to try to...
                                          03-12-2023, 05:05 AM
                                        • fanaticgames
                                          Samsung UE32D4010 Backlight problem, led ok
                                          by fanaticgames
                                          hello I have a backlight problem on this TV, if I unplug the cn201 cable the backlight works perfectly and the voltages are 13v if I connect the cn201 cable the backlight goes off and the voltage drops to 12v, I assume it's a motherboard problem, the question is has anyone had a similar problem? I want to understand if the motherboard is repairable or it's not worth wasting time...
                                          02-22-2023, 09:46 AM
                                        • Honziq
                                          Backlight problem - Asus M3200WU, board Gapal LA-L291p
                                          by Honziq
                                          I have this All-in-one PC, after SSD change there is no picture. I was found out it is a backlight problem, but LEDs are OK. There is 4 led strings each working on 42,4V, but from board is comming only 5V.
                                          I was repaired many backlights before but this design i will not understand.
                                          For me it looks like it is waiting for some signal from screen to start up the backlight or something like this. Nothing seems to be damaged or shorted here.
                                          Can someone explain me please what to do, what to check?
                                          Thanks....
                                          11-20-2024, 01:24 PM
                                        • grbo92
                                          Backlight problem Acer LA-031P
                                          by grbo92
                                          i have one acer Nitro 5 without backlight on my desk.
                                          Mainboard model: LA-L031P GH53Z REV 1B
                                          Attached schematics and boardview are REV 1A, slightly different as REV 1B.
                                          11411_LA-L031P-Acer_Nitro_5_AN515-45_AN517-41-GH53Z_Rev_ (1).zip
                                          Repair history: customer cleaned dust and changed thermal paste, shortly after that there was no light
                                          Notebook boots without problem and shows only image without backlight, HDMI output working. Optical inspection done, no burned or broken components. Tested also with a new display module....
                                          09-09-2024, 03:49 AM
