Samsung Tv H6400 48" to 40" Mainboard Swap
  • omnivortex
    • 20
    • Indonesia
    Hello Everyone , my 40 inch H6400 tv is accidentally updated to the newest firmware and right after that the picture of the tv has gone way way ugly than before since i can't find the earlier firmware file for my tv suddenly out of nowhere i have this idea. And my question is is it possible to swap the mainboard with a bigger inch size H6400? Thx for the help
  • chrismurphy
    • May 2014
    • 251
    • australia
    Re: Samsung Tv H6400 48" to 40" Mainboard Swap
    ? what is the issue , did the tv update itself or did you update it
    The board change is a bad move fix the issue
    • omnivortex
      • 20
      • Indonesia
      Oh i see. it was my little cousin that accidentally push the ok button when the update notification suddenly showed up , i've already turn off the auto update but sometimes it's still appear randomly. The previous firmware when the picture is still excellent is 2140 and the current firmware after update is 2180.
      My friend also has the unused H6400 tv but his version is the 48 inch and the firmware is 2140 i've also check the mainboard type and its the exact same as mine that's one of the reason that makes me consider about swapping the mainboard. is there any other solution to bring back the previous firmware?
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        You could probably try a reset to Factory settings.....I don't know if that will work.......
        • zomi
          • Nov 2011
          • 505
          You need to access service menu and change the panel type when going from different size panels
          worth a try
          • freakaftr8
            • Oct 2012
            • 3743
            Maybe get into service menu with your board. Figure out panel type. A maybe bit or panel type changed?
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              what seems to be wrong since the firmware upgrade what are you not happy with ?
              • omnivortex
                • 20
                • Indonesia
                Yeah i have try it too but its only reset the tv apps and settings to the factory default
                The Firmware is still the same
                • omnivortex
                  • 20
                  • Indonesia
                  worth a try
                  Oh i see , but where is the exact location of this panel type option after entering the service menu?
                  • omnivortex
                    • 20
                    • Indonesia
                    Yeah it seem like it
                    • omnivortex
                      • 20
                      • Indonesia
                      The first noticeable issue is the change of the picture characteristic now the picture becomes more darker and dull than before its like it has lost a lot of contrast and brightness and also when watching a HD channel or movie from usb it doesn't feel like a 1080p HD but more like watching a 480p resolution noise and jagged everywhere. second issue is that the Tv wifi easily disconnected by itself randomly.
                      No matter how hard i tweak the picture setting it still can't go back like before it was
                        09-07-2024, 05:50 AM
                      • GeckoGreen
                        Samsung service bulletin: need firmware file for PN63C550 TV
                        by GeckoGreen
                        I'm hoping someone with access to the Samsung GSPN can help me. I need someone with access to download a firmware file for my PN63C550 TV, as it will fix a problem per the Samsung service bulletin.
                        You can reference Samsung bulletin #:ASC20130528001 and I need the [2D63]LOGIC.bin file please.
                        The full service bulletin is linked here: https://www.avsforum.com/attachments...3-pdf.1080602/
                        Will you please help me get the [2D63]LOGIC.bin file for my TV?
                        05-17-2025, 02:47 PM
                      • sikocan
                        NP930XED Samsung Galaxy Book2 Pro Laptop PD Firmware Loop
                        by sikocan
                        I hope this message finds you well. I wanted to share a recent experience I had with a laptop that had a Type-C Port issue, specifically related to a PD (Power Delivery) controller problem. After replacing the damaged PD controller chip with a new one I purchased from AliExpress, the laptop now charges properly and negotiates power as expected, allowing the device to power up. I've replaced this chip twice just in case.
                        However, it seems that the laptop's BIOS is detecting an older version of the PD Firmware on the newly installed chip. As a result, it attempts...
                        01-11-2024, 01:47 AM
                      • Mirenia
                        Samsung UEMU6199U - no Standby - bad Firmware?
                        by Mirenia
                        I've got a Samsung UEMU6199U which has no Standby LED and no reaction if try turning it on.
                        Voltages on the power supply board is okay. Backlight test is also okay.
                        I read about a corrupt firmware on IC1604 on some models, did a dump of this IC and turns out: First sectors are empty.
                        So I think my TV has exactly this issue.
                        Can someone please fix the dump?
                        And how do you do that?
                        As I understand you fill in the empty sectors and leave the rest as it is. But where do you get the "information" of what you...
                        05-12-2025, 06:13 AM
                      • bohaboha
                        ADVICE FOR SAMSUNG MAINBOARD COMPTABILITY
                        by bohaboha
                        Hello all of you can any one tell if this Samsung Mainboard BN96-50992B 32" UE32T5300CK is compatible SAMSUNG UE32T5300AK ?...
                        04-19-2025, 01:47 PM
