Vizio E420VSE Brown/black strip running down side of tv
  • S.gilletly
    • Nov 2017
    • 28
    Hey guys quick question TV has a brown blotch on the left-hand side running down the screen and I just want to verify if replacing the t-con board will solve the issue here is a picture any information will help thanks
  • freakaftr8
    • Oct 2012
    • 3743
    Re: Vizio E420VSE Brown/black strip running down side of tv
    By the looks of that picture I'm seeing a lot more problems than just the Brown blotch on the left side. Can you show us a picture of what the TV looks like with an all white picture or a bright scene. I see a subtle dark line going through the center to left of the screen just below center point
    • freakaftr8
      • Oct 2012
      • 3743
      Now that I look at the picture again it looks as if that would be part of the image that is portrayed on the screen at the moment. The blotch is not repairable with a replacement tcon board this is either a panel issue or something behind the panel maybe dirt against the backlights
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        I agree that the black blob does look like the panel is suffering from the typical LCD mura problem.
        • S.gilletly
          • Nov 2017
          • 28
          when you say panel issue what would I be looking to replace to fix the panel? I am not experienced at repairs but I do them on the fly.
          • freakaftr8
            • Oct 2012
            • 3743
            The panel were referring to the LCD screen itself. It is not replaceable. The cost if you were to find this LCD panel would far exceed the cost of a new TV so therefore I would say probably get a new TV unfortunately.
            • S.gilletly
              • Nov 2017
              • 28
              Thank you I saw a video on "youtube" and this guy had the same issue on his tv and he took a wooden broom handle and waked the corner of his tv fairly hard where the discolor was and somehow that fixed the issue. Has anyone ever heard of that before?
              • freakaftr8
                • Oct 2012
                • 3743
                For this kind of symptom probably not. If the guy whacked to the TV with a broom at all it was probably of intermittent connection to an LED
                • bscottjohnston
                  Vizio M70-C3 LED Strip Repair
                  by bscottjohnston
                  Well, I'm kinda on a roll having fun fixing LED TVs. I have a question for those who have wandered into the arena of fixing your own LED strips. I bought a "cooker" on Amazon whereby it heats the strip so you can extract the LEDs. I successfully rebuilt the 10 of 16 that were bad. BUT - when I put the TV back together at certain times (white screen is really noticeable), I see what I would call a halo effect coming from some of the LEDs. The soldering station discolored the strip where I was working immediately.
                  Have any of you encountered this and if so what caused it?...
                  08-07-2023, 10:07 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • adelage
                  220v Led strip flickering
                  by adelage
                  Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
                  I know that the best solution would be to get a voltage...
                  11-03-2024, 09:49 AM
                • edugimeno
                  Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
                  by edugimeno
                  Hi There!
                  I'm trying to help my friend who owns a restaurant be just bought.
                  He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
                  It's stuck using, I guess, the 2 sided tape that comes with the strip
                  The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
                  09-05-2024, 09:34 AM
