Lg-50pv450-ua
  • fcisolutions
    • Jan 2017
    • 205
    Lg-50pv450-ua
    Have an LG Plasma that has sound but no picture tested the VA and VS on both the Y and Z boards. Both were good but replaced the Y board with no change. Thinking now should I replace the Z board or possible buffers. Any help would be great thanks...
    Re: Lg-50pv450-ua
    Control board LEDs lit up?
    Test patterns run?
    Check for illumination of screen in dark room / initial flash on screen on power up?
    Verified Vsc, -Vy, and Vzbias? Checked all fuses?
    • fcisolutions
      • Jan 2017
      • 205
      Re: Lg-50pv450-ua
      No LED's lit on control board. Not sure about the test patterns, I downloaded the manual and I have been checking it. No illumination at all on screen or initial flash, I had all the lights out. Rechecked all fuses and they are good.
      • fcisolutions
        • Jan 2017
        • 205
        Re: Lg-50pv450-ua
        Rechecked the control board. With the Z board disconnected I am getting a blink code of 3 quick blinks and then 1 longer one and then it recycles.
          Re: Lg-50pv450-ua
          So you are saying no light from the control board with the Z connected
          The blink code indicates temperature. As far as I know it's not a fault code. But that's not too important. If the LED is not blinking at all with the Z hooked up, something is shorted.
          • fcisolutions
            • Jan 2017
            • 205
            Re: Lg-50pv450-ua
            I cleaned the connections and reattached. Now it is blinking with everything hooked back up. Still just getting sound no picture.
              Re: Lg-50pv450-ua
              Then you need to do the checks I outlined above and get back to us with the results.
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • jb_Bak
                by jb_Bak
                CN6401
                Pin 01 NC
                Pin 02 NC
                Pin 03 "BL_ON": 0V
                Pin 04 "N/C"
                Pin 05 "STBY 3.3V": 3.5V
                Pin 06 "GND": N/C
                Pin 07 "AC_OFF"...
                09-27-2021, 04:52 PM
