Vestel 17mbxx console mode
  • jellytot
    • Mar 2015
    • 42
    • Ireland
    Hi. Does anyone know how to stop the reboot cycle when you run "crash_the_system" command in terminal mode of the vestel 17mb series
    mainboards to get into the conf and vendor Dirs? I'm obviously missing something simple I tried the WATCHDOG 1 command but nothing
    seems to happen..any help on this is most appreciated..
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • gabri2211
    Xbox Series X Console Won't Turn On - Broken Nexus Connector on Mainboard
    by gabri2211
    Inside the console there is a small circuit board (see photo) that contains the main power switch, the one on the front.
    This circuit board connects to a 10-pin flat cable called NEXUS that terminates on the motherboard.
    This NEXUS connector broke.
    Can anyone tell me, while waiting for a replacement, if it's possible to turn on the Xbox by disconnecting this circuit board and making some modifications (like adding a small power button) on the motherboard?
    The Xbox has a power supply that provides 12 volts on all outputs, so the power...
    07-28-2025, 07:13 PM
  • France_53
    Vestel tv, how to flip the image?
    by France_53
    Hello everyone from Italy, I'm here to ask for help on a Vestel TV, I've had a Vestel TV branded "XD" with a broken screen for years, but now I've found a Telefunken (still Vestel but older) and I've mounted the panel on the "XD" TV, it works, but the screen is upside down, given that Vestel does not allow you to rotate the image from the service menu, does anyone know how to solve the problem? the original panel is marked ves315WNDS-2D-N12 while the main board 17mb110, the panel I mounted instead in the tv (from the telefunken) is a ves315WNDA-02. ... It is not worth repairing...
    05-12-2024, 05:22 AM
  • FlailingEngineer
    Help with Bush Tv (Vestel 17mb95m Mainboard)
    by FlailingEngineer
    Hi, I was recently given a Bush Smart TV by a friend and the main board seems to be hanging on by a thread.
    Before we get to that, my first obstacle was figuring out the model number since the back sticker has gone for a walk. Upon taking off the back case, I noticed the following Vestel parts, 17MB95m mainboard, 17IPS71 (what I'd assume is power supply) and a VES420UNVL-3D-S02 display panel. After doing some research I think the TV I have is a Bush ELED42240FHDCNTD3D, based on the matching image here (https://www.manualslib.com/manual/11...td3d.html#manu...
    05-31-2023, 06:52 AM
  • hazi12
    Vestel main board 17MB140TC
    by hazi12
    Hello, board 17MB140TC, I need to change the remote control in Vestel tool box 1.1. The original is there
    Rc48xx_2D and I want to install TOSHIBA-Rc481xx, but the program says that a maximum of 9 characters can be entered. I only entered Rc481xx and the program does not accept the driver I have in the original. Does anyone know how to do this? Other Vestel codes work.
    I can send a dump....
    10-01-2025, 01:28 PM
