60PK550 not going.
  • happyade123
    • Feb 2015
    • 92
    60PK550 not going.
    Ok attempt number two.
    Tv Model number:Lg Plasma 2010 60 PK550-AA
    With all boards connected in Television. I get the standby red light and intermittent closing of both relays followed by one quick click directly afterwards. When I get the relays to close I have approx 390v dc on the filter capacitors. When the relays don't close I only have 2 volts yet still have the standby light . What I have just noticed is if I discharge the filter capacitors the relays will close every time but it will still make the 3 clicks. Originally I had only 3 to 4 volts on standby but after changing the 3BR1565 JF Standby 5 volt Regulator I now have exactly 5.14v.
    I am certain my issue lies on the power board as when I run power supply on it's own I still don't get any other voltages, even with the light bulb in series hooked up too the vs and ground.I also hooked a 100 ohm resistor between pin 14 5volt standby and RL on but still no change to the readings.
    Power Board Number is EAY60968901 .
    P813
    1-2 (17v) 0v
    3-4 (Gnd) x
    5-7 (5v) 0
    8 (Error Det) 4.9v briefly
    9-12 (Gnd) x
    13-14 (STBY 5v) 5.16v
    15 (RL-ON) 0v
    16 (AC Det) 4.91 briefly
    17 (M5 on) 1.11 volts then disappears quickly
    18 Auto Ground 4.87 volts ???
    No VA AND NO VS Or M5V or 17V
    All Filter Capacitors reach 380volts Dc before discharging.
    Question :How come the relays are closing and yet no voltage high or low on RL –ON?
    Why does Voltage exist on the Auto Ground pin? Does that mean IC 701 is not doing it's job (submicom on bottom of power board)
    Is 380 volts too high for the filter capacitors?
    How can I isolate the source of the problem? No obvious shorts and all capacitors tested ok as do both relays.
  • happyade123
    • Feb 2015
    • 92
    Re: 60PK550 not going.
    Here are much more detailed pics .
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      Have look here it will help
      https://www.youtube.com/watch?v=NmifFBrB8BM
      http://tomtechtodrepair.blogspot.co....c-and-diy.html
      • happyade123
        • Feb 2015
        • 92
        Thanks heaps Cyberhack some very useful information.
        • maxvalutech
          • 804
          • australia
          Adrian if no response to input by others your post will fade to oblivion. So did you do the tests as above ? These tests are basically the ones on page I previously referred you to in training manual.
          • happyade123
            • Feb 2015
            • 92
            Hi Maxvalutech. Sorry for the delay,blew several components in the primary of the power supply including 5 rectifier diodes, 1 x 15 amp fuse and two NTCs so have just managed to replace them all.
            In regards to your Test points.
            Yes voltage is correct at main filter capacitors. The light bulb jig does not light up and there is no VS or VA Voltage present. No voltage exists on RL ON and when I ground the Auto ground pin, the power supply won’t even start. Both Relays appear to be clicking as when I first apply power there is 2 very quick clicks followed by one click, so I am assuming one of the relays is turning off again. Standby to RL On also produces no results.
            Standby(5.14v) to M on produces no results either. I am assuming it is going into protection mode but I have no idea why. Any other ideas, suggestions?
            • u666sa
              HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
              by u666sa
              Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
              Platform: ipa32 la-m024p rev 1b
              Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
              I found a short on the other side:
              10-04-2025, 05:03 PM
            • Mcfeetroy
              Fishing bite alarm drains battery
              by Mcfeetroy
              Good day to all. The bite alarm drains 9-volt Krona batteries. Current consumption when switched on is about 50 mA. I wiped the board from oxides, I will attach a photo (on the board there is a j3y transistor and a 7533 stabilizer, the microcircuit is erased = (the 3.3-volt stabilizer heats up weakly. I replaced it, nothing changed. I unsoldered the microcircuit, the consumption disappeared. The resistance on the pins of the unsoldered microcircuit from the point clockwise is more than 2 megaohms, the 11th leg is presumably ground. I warmed up the microcircuit, the consumption does not change....
              08-01-2025, 03:52 AM
            • tvguy12012012120
              by tvguy12012012120
              02-07-2025, 05:13 PM
            • stylishconsultant
              un60j620dafxza - Samsung No Display Problem
              by stylishconsultant
              Hi All,
              Need help.
              I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
              So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
              problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
              might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
              09-04-2024, 03:26 AM
            • fharris1977
              Vizio D50u-D1 Dead Set No Standby
              by fharris1977
              Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
              12-28-2023, 10:25 AM
