EW39T4LZ westinghouse LCD LED backlight bad need a part / help
+ More Options
Posts
  • shelby5041
    • Feb 2009
    • 1504
    • united states of america usa
    hi
    i have a westinghouse 39 inch lcd led tv
    model EW39T4LZ
    backlight wont come on...i have power to BL connector 64V
    i took tv apart and found 2 LEds on the 1 of 2 strips were fried...
    im looking for a LED strip part# TC390HJ01-R213
    cant find anywhere online...
    or does anyone know how if and how i can bypass the two bad LEDS...they are the last 2 on the end of the strip..the leds are very very small ..
    this tv only has 2 strips up top that light up the entire screen....
  • shelby5041
    • Feb 2009
    • 1504
    Re: EW39T4LZ westinghouse LCD LED backlight bad need a part / help
    the photo i included was one from online..same part#
    • shelby5041
      • Feb 2009
      • 1504
      Are the leds in series?
      If so couldnt i just bypass the end 2 bad leds?
      How would i jumper wire to do this since its at the end of the strip?
      • shelby5041
        • Feb 2009
        • 1504
        Please disregard the bypassing...i tried and i dont have the proper equip and skills to do it...the leds are way too small to work with
        Does anyone know where i can locate replacement led strip?
        • lmcancu
          RCA RLDED 4331B: 43 inch LED TV: Backlight issue
          by lmcancu
          Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
          Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
          Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
          Instead of putting it back together I decided to replace...
          04-01-2023, 01:11 PM
        • Tynan Dill
          by Tynan Dill
          Assuming...
          11-22-2024, 01:46 PM
        • edugimeno
          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
          by edugimeno
          Hi There!
          I'm trying to help my friend who owns a restaurant be just bought.
          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
          It's stuck using, I guess, the 2 sided tape that comes with the strip
          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
          09-05-2024, 09:34 AM
        • hollox123
          ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
          by hollox123
          Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
          1. Laptop keyboard doesn't work
          2. The backlight on the laptop keyboard doesn't work
          3. The x2 side LEDs (red) on the laptop don't work
          The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
          I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
          But I am strongly aiming that it is somehow a BIOS-related problem,...
          05-11-2025, 08:05 AM
        • spirittoo
          Sceptre 48" TV backlight LED`s
          by spirittoo
          Trying to fix a backlight problem with a Sceptre 48" TV.
          I found replacement strips with the same part number as the strips in the Sceptre, but the new backlight strips have 5 leds per strip and the ones in the tv has 6.
          So I decided to replace the leds instead. I found 3 bad ones. I had no problem removing the bad ones with a heat gun, they came right out. However the leds on the replacement strip would not come out with heat. I use my solder iron as well, they will not come off.
          Anyone know how I can remove those leds without damaging them?
          11-11-2023, 10:23 AM
