Hitachi 57f59a
  • fixerupper75
    • Oct 2014
    • 125
    • us
    Hitachi 57f59a
    Do anyone know if hitachi 57f59a has a bulb and where it is located?
  • R_J
    • Jun 2012
    • 9623
    Re: Hitachi 57f59a
    No lamp, it has 3 crt's Red, Green, Blue. What is the problem?
    • ezenia
      LUMIMAN Smart Bulb IC ID?
      by ezenia
      I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
      In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
      04-28-2025, 05:56 PM
    • repair-it
      TOSHIBA DLP 52HM95 How to reset timer module on bulb
      by repair-it
      I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
      Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
      10-11-2023, 07:18 PM
    • Jaime Morillo
      Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
      by Jaime Morillo
      Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
      The TV was stuck on the logo and I couldn't access the update menu.
      I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
      The image result was good, but the image is inverted.
      The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
      Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
      08-18-2025, 11:38 AM
    • vestaviascott
      Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
      by vestaviascott
      Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
      Here's what happens:
      1) Power on
      2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
      3) Blue status light flashes for appx 4 minutes...
      07-29-2020, 06:08 AM
    • Dan John
      Vivitek DLP D508 Projector - NO POWER
      by Dan John
      Greetings, everyone.
      I am a beginner when it comes to electronics, so I am asking this amazing community for some help, once again.
      I have a Vivitek DLP D520 projector but there is no power going to the device. Upon plugging it in, there are no indications that it is receiving power; no lit LEDs, or anything. Apart from checking the connectors, the bridge rectifier, and the fuse, which all appear to be good, I am stuck as to what subsequent steps to take. A visual inspection did not reveal anything, either. Can anyone please advise me on what other steps I can take to...
      09-11-2025, 01:18 AM
