Sony kdl-46xbr4 won't turn on with no blinking standby light
  • wtuser
    • Nov 2017
    • US
    My Sony Bravia doesn't show any picture or sound with power LED staying green and Sony logo lit. When opened the back to clean, noticed no glow on backlights. No capacitors look bulged or burnt and there is normal relay click. Odd thing is, I don't get any blinks (Red) on standby light indicating error. FB1 has heartbeat so I thought TCON might be an issue but since I have no glow, I'm thinking driver board (DF2&3) or the inverter boards. Worst case bad panel. I've checked standby voltage along with 12v/6v references on DF2&3 and all look normal. I did notice no 3.3v inverter trigger on GF1 but not sure if it should be there if there is no video source (HDMI) is plugged in.
    I did try to take power off DF2&3 at a time to see if I get panel to glow with some sort of picture on either side but nothing. Again, this is hard because I have no blinks on standby light. I'm leaning towards power GF1or AU board.
    Any help in isolating the problem would be greatly appreciated.
  • YasaCh
    Sony kdl 40p5500 red light keeps blinking 3 times
    by YasaCh
    Hello...
    my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
    i opened the back cover no sign of damage on the powery suply or motherboard
    when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
    another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
    07-07-2025, 11:53 AM
  • mecha1166
    QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
    by mecha1166
    I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
    03-28-2024, 08:31 AM
  • androripara
    Sony Bravia 55HX820 - 4 times blinking red standby led
    by androripara
    i am trying to repair a Sony KDL-55HX820 led TV which is throwing error code 4 (standby led flashing four times).
    I followed the troubleshooting flowchart at page 69, and between pin1 and pin7 of CN6002 i am reading 1.91V so i guess i can rule out the B Board as the culprit.
    Before ordering new G* Boards (by the way, should i change both? it is not specified in the manual) i wanted to try and do more advanced troubleshooting since i've read in other threads people resolving their problems on the 46/55 HX 820/823/825 models by replacing the Samsung led...
    10-19-2023, 05:16 AM
  • ChristianBr01
    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
    by ChristianBr01
    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
    04-23-2025, 01:48 AM
  • noinimod
    Sony 55X900E no standby light, no power. Replaced mainboard already
    by noinimod
    No standby red light, nothing
    This Sony has a separate AC->DC power adapter supplying 19.5V to the TV power board (JK3)
    Disconnected JK3 power board from main board, checked voltages on all the pin outs
    At a few pins I can see the power supply providing 19.5V to the main board
    Based on the service manual triage.. it seems to be pointing towards the power board (JK3) being the most possible culprit
    LED light turns on when I disconnect LED driver board ribbon from mainboard (so i thought it is the mainboard,...
    12-22-2021, 12:58 AM
