Samsung ln46d550
  • heavymachines
    • Mar 2011
    • 1028
    Samsung ln46d550
    Ok this tv is getting no backlights but does have an image seen with a flashlight.
    However when i check the primary caps on power board it is only reaching about 190 volts not getting the boosted voltage needed for backlights.
  • heavymachines
    • Mar 2011
    • 1028
    Re: Samsung ln46d550
    pics provided by shop jimmy
    • dskall
      • Oct 2016
      • 2905
      • usa
      So in stand by you have around 162vdc. So you have some boost. Check your resistors around pfc controller. What is number on controller chip?
      • attainteddragon
        • Apr 2013
        • 764
        • australia
        is 190v in reference to cp 802 and cp803?
        i don't see you getting your secondaries active with that.
        is ps/on staying high?
        WHY CAN'T PHILIPS USE PHILLIPS HEAD SCREWS?
        • heavymachines
          • Mar 2011
          • 1028
          Well actually it's gotten worse. on or off now cp802 and 803 is only getting 171 volts. ps-on is getting .005 volts off and 3.48volts on.
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            You don't seem to have a PSU problem. I am almost certain you have a failed backlights problem
            • heavymachines
              • Mar 2011
              • 1028
              primary caps on ps is not boosting. only reaching 170 volts on or off now . could it not be boosting due to backlight failure?
              • heavymachines
                • Mar 2011
                • 1028
                Controller ici801 is bd9275f
                  IC in the PFC section will be ICP???? (Designator for the parts in PFC will have 'P' as part of the designator), so the PFC IC is ICP801.
                  Check DP810 for shorts or bad leakage resistance.
                  • heavymachines
                    • Mar 2011
                    • 1028
                    Ok learning. DP810 with one leg lifted reads 0 one way and .502 the other in circuit its dead short both ways. .000 in diode mode on fluke 75 multimeter.
                    Have much to learn about leakage and how to detect it.
                      "Ok learning. DP810 with one leg lifted reads 0 one way and .502 the other in circuit its dead short both ways. .000 in diode mode on fluke 75 multimeter"
                      I do not understand 'the other in circuit its dead short both ways'. What is 'the other' that shows dead short?
                      IF it shows dead short when measured in the circuit then the snubber cap is probably shorted out, that cap is connected in parallel with that PFC diode.
                      • heavymachines
                        • Mar 2011
                        • 1028
                        let me get more specific.
                        With diode dp810 in circuit it reads .000 both ways.
                        now with 1 leg lifted it reads 0 one way and .502 the other way
                        Snubber cap have no idea where i see cp804 and few other possibility. not an expert like u. i will check caps inline with that diode.
                        • heavymachines
                          • Mar 2011
                          • 1028
                          Hey that was it, checked cap CP820 and measured it in tester and it was junk measured like a resistor rather than cap. on DMM it measured short.
                          markings on it was 221 1k
                          replaced it with 221 2k and problem solved tv works now as it should. thanks budm .....
                            Thanks for the follow-up, that snubber cap is connected in parallel with that diode, those caps are common failures.
                            • heavymachines
                              • Mar 2011
                              • 1028
                              Thanks for tip.
                                09-07-2024, 05:50 AM
                              • max789
                                Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                                by max789
                                Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                                I made the following tests:
                                1. Disconnected the main board from Power Board = backlight works.
                                2. Connected the main board and disconnected the T-Con = backlights does not work.
                                So I ordered a main board from Ebay also BN41-02156A but from...
                                01-18-2024, 06:56 AM
                                09-06-2024, 11:40 PM
                                09-06-2024, 08:40 PM
