Sharp LC-42D64U... no video inputs work, OTA works
  • budwich
    • Jul 2015
    • 3097
    Re: Sharp LC-42D64U... no video inputs work, OTA works
    it is certainly worth an attempt. i have started to go thru the troubleshooting section of the SM... starting at "no composite video" on input 1,2,3. It gives some check points to look at so I will try to do some "checking" with my scope to see I can figure out anything. Hopefully I won't blow up the thing.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4543
      • Italy - Milan
      Maybe i'm inattentive, but i don't think that has a sense to follow the flow chart for no video, since you have near all inputs not working, since hdmi and composite follows a different path to the IC8001 CPU through different ICs, so unless those ICs have the same power supply at fault (watch for linear regulator on the main board) then the issue is software.
      • budwich
        • Jul 2015
        • 3097
        Hey Davi.p...
        we tried your suggestion with the hard reset from the 2 page of service menu (called industry init).... The "init" started for about 4-5 seconds... then the screen went red background and an error appeared with "industry init error ( 11)". At this point, the set was locked up with no response from the remote or panel buttons. Unplugging power took it back to "normal" set operation. Didn't find any thing on this error yet.
        Then we decided to do the "eep recovery" on page 32 of the service menu. Similar results... the item line shows some "progress marks" (ie. starting to do something) but then an "ERROR" word shows up. This time though we can power panel off with the side buttons. The panel starts up normally. So overall we were not able to cause a good reset of the panel either "hard" or thru "eep recovery"... :-(
        BUT through all this, all the analog video inputs work (ie. rca vid and svid) along with the ota tuner. This better than when we started so something happened. Still no hdmi, component and vga.
        It is looking more like a firmware / prom issue and probably needs the main board to be replaced.
        Not sure if the "error 11" means anything to anyone or points to something specific.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4543
          • Italy - Milan
          I hope i'm wrong but it seems this Sharp it is made in a very strange not convenient way, in all the other tv i know the firmware contains a copy of the standard settings for the eeprom so when config becomes corrupted a service reset will restore factory situation, but maybe i've heard this time ago, this is made so, the eeprom have a backup of settings in a certain area that are copied to the active area when you do a reset, unfortunately it seems corrupted so also the upgrade is no more possible so i need to find answers on the smnual or an eeprom dump.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4543
            • Italy - Milan
            No dump around... you can read it by another mainboard.
            • budwich
              • Jul 2015
              • 3097
              :-( It looks like we are stuck with tracking down a replacement main board.
              One other thing that is of note. The "plug detection" circuitry has some issue. On the first 3 ports (input 1,2,3), plug detection works as it should. The port is "not available" for input selection with nothing plugged into it. IF you plug into it, the port then gets "marked" and is available for selection. Port 1, 2, and 3 are analog / rca ports and are on the main sub input board that is across the bottom / bakc of the panel.
              On inputs 4-7, they have the "port available" mark always set, even though no plug inserted. Inputs 4-6 are hdmi and port 7 is vga. So there appears to be some issue with "hot plug detection" / "plug detection" circuitry on those. I haven't yet gone thru the SM to look at the flow to see what's up there but perhaps some form of "short" has made its way to the detection circuit such the pin 19 (I think for hdmi) is being detected across all the ports. Can't remember for vga, but some ground on one of the 15 pins also causes the same detection.
              In terms of board layout, hdmi 4 is on the side sub board while hdmi 5,6 and vga are on the main board.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4543
                • Italy - Milan
                #27
                This can be normal 'cause on Samsung tv ususally it is so...
                • budwich
                  • Jul 2015
                  • 3097
                  not sure (about hot plug / plug "sense"). On my other samsung set, it only shows / highlights inputs that have plugs in them and greys out others that are empty. most hdmi inputs that I have seen are normally "sensed" for cables using pin 19.
                  I am thinking there is an issue with the silicon graphics chip sii9185 which receive both hdmi signals and the vga signals based on the trouble flow charts and the board schematics, although the "plug check" for the vga thru some form of the eeprom for the DDC data (resolution capability checks).
                  OOPS... I screwed up... the sii9185 appears to only handle the hdmi. So vga goes else where.
                  further. The component (rgb / vga) go thru a TB1305FG. This "thing" needs some setup to provide the appropriate input and output signal manipulation. It would appear that indeed, the issues with the eep and subtending work area has a problem such the appropriate values are not being set in the subtending IC.
                  certainly well beyond my current knowledge level... :-)
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4543
                    • Italy - Milan
                    #29
                    The Samsung LCD i owned (more than 10) all shows some inputs without signal, it shows black screen and a box with the input name..
                    • budwich
                      • Jul 2015
                      • 3097
                      We decided to "throw in the towel" and buy a used main board off ebay. Fingers are crossed that it will resolve the issue as the panel's picture / display is very good.
                      • budwich
                        • Jul 2015
                        • 3097
                        Used main board installed today. Factory reset and everything is working so it would appear that possibly an eeprom corruption or otherwise. Anyways, friend is happy, me too.
                          HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                          This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                          09-12-2024, 02:00 PM
                        • SolarFlare
                          Mi TV 4 Pro-Samsung Panel LSC550FN20 - Video problem, backlight and Audio works fine.
                          by SolarFlare
                          My barely 3 year old TV has stopped displaying video, although the video output comes for a few seconds after turning ON which displays the manufacturers logo then shows the home screen (all this with some blue flicker) then the video goes blank and the screen is dark blue with the backlight on. The audio output works perfectly and the TV also takes in voice commands(smart TV).
                          The TCON board has the following Chips -
                          Samsung VTU63A0
                          RT6939 - 2nos.
                          and all these chips are getting real hot within a minute, I dont know if this is normal....
                          06-26-2022, 08:58 AM
                          GeForce RTX2080 Super Aero video gaming card issues help need
                          by sam_sam_sam
                          This is from my son’s gaming computer that at first had minor overheating issues when playing a very intense game with it causing the computer to crash or reboot
                          Then bough a new motherboard and a new computer case that a cooling system in it already installed also brought the cooling system for this video card but now the issue with it is that it randomly rebooted screen goes blank randomly and suddenly video freezing or started with video being there then blank screen and then the video comes back or it just stays blank for a while and then maybe it will come back but it...
                          05-07-2023, 08:12 AM
                        • FrancescoV
                          Onkyo HT-R390 no sound output, video output ok
                          by FrancescoV
                          Good morning everyone,
                          I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                          The firmware reported is the following:
                          M:1.00/11107BLP
                          D:?.??/????????
                          O:1.00/11107AL
                          The DSP firmware given the question marks seems corrupt.
                          On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                          05-11-2025, 02:59 AM
                          HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook Specification for Upgrade or Repair
                          This specification for the HP EliteBook x360 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and 1030 G2 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users...
                          09-06-2024, 06:20 AM
