Panasonic TXP50 S21 B
  • Techstar
    Tv Restoration
    • Dec 2012
    • 122
    • United Kingdom.
    When this Tv is switched on the relay is heard to click , the tv won't come to life , the front LED flashes 4 times.
  • Techstar
    Tv Restoration
    • Dec 2012
    • 122
    • United Kingdom.
    Re: Panasonic TXP50 S21 B
    I have just done a few quick tests and found the resistance across the SC board power connection is 12 ohms , the reading across the SS board power connector is around 1 .3 Meg Ohm. Does this seem too high a resistance across the SS board supply ?
    • tw2005
      • Oct 2011
      • 6458
      wrong question. does 12 ohms appear to be a short cct on the SC?
      answer is yes. I would use the search function and target posts on any 2010 FHD model and also TNPA5105 or even TNPA5081.
      There will be plenty of info but basically the SC has shorted, that shorts the P board, that then triggers SOS 4. other common code would be 10 blink.
      • Rensiee
        Panasonic TH-50PX8EA Black screen, only relay clicks
        by Rensiee
        I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
        I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
        When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
        I have measured the voltage in the VSUS line, which...
        06-18-2024, 12:58 PM
      • CoinCoin88
        Garage door RX unit (Cardin S38C) does not short relay to send opening signal
        by CoinCoin88
        I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
        Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
        09-15-2025, 03:36 AM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
      • CuriousJohn
        Burco boiler power problem
        by CuriousJohn
        Burco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
        Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
        This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot...
        12-22-2024, 10:25 AM
      • Andre Gilbert
        by Andre Gilbert
        11-20-2024, 08:52 PM
